EGT guage going crazy!!!
Old Mar 23, 2004 | 10:16 PM
Cornbread Jr.'s Avatar
Default EGT guage going crazy!!!
I can't think of anywhere else to post this and I figured that since probably everyone with an EGT guage has a turbo that this would be the place to go. Every time I drive over a bump in the road my EGT guage needle jumps up and the warning light flashes showing me where the warning is set at. It's not that the temps. are going up, just that the needle keeps jumping around. I have a GReddy 60mm guage with peak and hold and warning feature. I checked all the wires to make sure everything is connected and nothing is pinched. Does anyone have any ideas as to what might be causing this?
Old Mar 23, 2004 | 10:18 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: EGT guage going crazy!!! (Cornbread Jr.)
Mabye the queen needs more padding in her seat to cushion the bumps..JK
It has to be an electrical problem.
art
Old Mar 23, 2004 | 10:20 PM
Default Re: EGT guage going crazy!!! (Arturbo)
My EDFC backlight stopped working too . I think I just have too much electronic crap in my car. I need to just do what Allen does, a boost guage and that's it .
Old Mar 23, 2004 | 10:34 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cornbread Jr. &raquo;</TD></TR><TR><TD CLASS="quote">My EDFC backlight stopped working too . I think I just have too much electronic crap in my car. I need to just do what Allen does, a boost guage and that's it .</TD></TR></TABLE>
Less stuff less places to search for a problem but i thikn EGT gauges come in handy
but most likely it's a electrical problem though.
Old Mar 24, 2004 | 07:42 AM
platinum00's Avatar
Default Re: EGT guage going crazy!!! (HybridcivicLS-T)
it's 100% a ground problem
took me a while to find this on serveral cars.
check the block grounds.
platinum.
Old Mar 24, 2004 | 09:34 AM
falcongsr's Avatar
What is this crap?
it may not be a ground problem, but it is likely to be that or just a bad connection somewhere. always solder connections!
Old Mar 24, 2004 | 12:58 PM
Default Re: (falconGSR)
I checked all the connections twice and couldn't find any bad connections or loose wires. I wonder if the guage itself is just bad? I can tap the side of where the guage is mounted and the needle will do the same thing.
Old Mar 24, 2004 | 01:04 PM
platinum00's Avatar
Default Re: (Cornbread Jr.)
if you take the gauge out of the manifold and let it hang in the air does it do the same thing. if it works correctly it's ground problem. not a ground problem with the wires on the gauge. the main car ground problem
the probe grounds itself through the manifold.
if it's still erratic, then try another gauge.
platinum.
Old Mar 24, 2004 | 03:02 PM
Default Re: (platinum00)
Thanks for the suggestion. I'll try that. I talked to a guy at GReddy and he said I could send the guage to them and they could take a look at it. He said it takes a week though . Hopefully I can fix it myself.
plusONE jboy
Apr 19, 2004 12:30 PM
othick
Dec 26, 2003 12:34 AM
Mr. Vapor
Mar 24, 2003 07:05 PM
BlueShadow
Jan 16, 2003 09:56 PM
BluLuder
Nov 15, 2001 12:29 PM
