EG Turbo Build
Old May 31, 2013 | 04:05 PM
flycivicsi's Avatar
Default EG Turbo Build
Let me start off by saying this was my first real turbo build. I have been learning lots along the way and would appreciate the negative comments to yourself. If you have some constructive criticism I can appreciate that.
Alright lets begin
First to start out I purchased this 1995 civic for the most part already built.
Honestly I purchased this car for the shell/interior, exterior mods. The person who built this car did an amazing job with it. The only part I was not satisfied with was the motor/turbo set up.
Previous set up
JDM b18c Motor
Eagle rods
CP 9:1 pistons
Sunk2 valve train
Peakboost turbo kit
This motor made 320ish horse.
I started to pull the motor to get ready for the new heart
The first purchase was a new block
B20b
Darton sleeved 84.5mm
cp 10:1 compression
eagle rods
balanced to 12000rpms
I already picked out my turbo which I had from a previous build (precision 6262 dual ball bearing turbo). This turbo would mount to the original peakboost kit and would be the only upgrade that I would make…………… or so I thought….
The next purchase was some DSS 5.9 axles from a local member on this club.
about a week later ordered a new fuel system
This Consisted of dual inline bosch 044 fuel pumps, ID1000cc injectors, -10an feed and -8an return. The plan was to sump my stock fuel tank.
After some research I decided to upgrade my fuel tank to an FCS 9 gallon fuel cell.
I then came across a great deal on some ID2000 injectors. I quickly scooped them up and sold the ID1000's. To finish off the fuel system I ordered a dual bosch pump mounting bracket and a fuel filter mounting bracket. I also have a spare aem fuel rail with aem fuel pressure regulator to use.(may upgrade).
After some time passed the next item on the list was a new rad, rad fan and rad hoses. Went with a Koyo rad, and mishimoto fan/hoses.
I then wanted to run a breather box for both my valve cover and block. I found a guy on Honda -tech selling a set up so I scooped it up.
As time went on I became hung up on getting a full race manifold. I finally decided to bite the bullet and purchased a Full race top mount T04 twin scroll manifold with black heat coating. The only downside was the precision 6262 did not have the option for a T04 divided housing.
Old May 31, 2013 | 04:07 PM
flycivicsi's Avatar
Default Re: EG Turbo Build
So I opted to sell the 6262 and picked a custom built Garrett dual ball bearing GT42r with a 76mm billet wheel…
Seeing as i went with the new manifold the current Tial 38mm wastegate would not do. I picked up 2 tial 44mm wastegates.
Then of course I started crunching numbers of what I wanted my power goals to be and I felt that the current motor would not hold the power levels I wanted.
So with that I went with a new block/head.
Ls block
KMS high flow oil pump
Acl race bearings
Eagle crank
Full arp studs
Bc 625+ rods
85mm JE 10.5:1 pistons
Darton sleeves
Ls/vtec conversion
Head
Ported/Polished B16 Head
Ferrea oversized valves
Ferrea dual valve springs
Bc stage 2 turbo cams
Adjustable cam gears
Gates Kevlar timing belt
Type r water pump
Morosso 5qt tapped oil pan
The plan is to have this car on the road by July 15th 2013.
The last few Items I need to purchase are
New Tranny
Clutch
3" intercooler piping
Few more fittings
and few more things
Old May 31, 2013 | 04:09 PM
flycivicsi's Avatar
Here some picks with the motor out. Next step is to get the engine bay ready for shaving and paint. Also I will be powdercoating most of my suspension components black and pretty much anything else I can get my hands on.
Also the newer SLS 4" downpipe
Old Jun 2, 2013 | 06:18 AM
KRITIK's Avatar
nice collection of parts, in for the finish
Old Jun 2, 2013 | 11:06 AM
familysedan2's Avatar
Nice setup man! And im jealous.. I wish my garrett was oil/sprite cooled lol.
In for results! What are your expected power goals for this beast?
Old Jun 2, 2013 | 12:03 PM
flycivicsi's Avatar
Ya I said screw using water... Going Sprite cooled.. I don't want to throw any numbers out as I may dissapoint myself and be made a food of by others. I am hoping to order all my tuck parts fairly soon then take the car into the body shop to have the bay completed... I should have taken more picks of the car going through its changes but I waited way to long then decided to do a build thread.
I also believe its one thing to show all the parts you have.. but another to actually get them on the car. I hope to have this car done by July 30th now... Baby on the way in the next couple of weeks will slow this down greatly..
Old Jun 2, 2013 | 12:51 PM
That's respectable tho, either way this is a nice build and I'm pumped to see it finish up! I am still a bit out from tuning, but my setup is a little more basic then yours lol.
You need to throw the baby recaro seat on the list yet tho, blue or pink?
Congrats sir!
Old Jun 2, 2013 | 03:52 PM
flycivicsi's Avatar
it will be a pink baby seat. lol The wife gave me 2 options sell the civic or sell The m3.. and get a 4 door.. So I let the M3 go.. and don't regret it for a second.
Old Jun 2, 2013 | 04:05 PM
th3pwn3r's Avatar
Oh god, never in my life have I let a woman control what I do BUT I've never been married and don't have kids so what do I know.
Anyways, I want to see how that fuel cell mounts up, I haven't seen one of those installed yet.
Old Jun 2, 2013 | 05:06 PM
flycivicsi's Avatar
Will post picks once I have it put in.. Should fit greatly..
Old Jun 2, 2013 | 06:34 PM
Great choice
And most definitely take pics through the rest of the assembly. By the looks of your parts stash, this is going to be a monster lol
Old Jun 3, 2013 | 03:31 PM
flycivicsi's Avatar
Great choice
Yes it was a sad day to see the M3 go... But after owning it for over a year and having my civic I struggled to enjoy it near as much as the civic.
Old Jun 4, 2013 | 05:08 PM
peaceable's Avatar
A nice list of parts to make it go. Are you planning on cooling it to make it more reliable?
Old Jun 4, 2013 | 05:13 PM
Ratt731's Avatar
Nice build so far, cant wait for pics of your progression
Old Jun 4, 2013 | 05:22 PM
flycivicsi's Avatar
yes I will be... I have not decided yet on the exactly what I want..
Old Jun 4, 2013 | 06:12 PM
B and B's Avatar
Loved
Community Favorite
You can say that again. Baby girl at that.
Old Jun 4, 2013 | 07:41 PM
peaceable's Avatar
I'm planning on doing my EG too if I ever get through with body and paint. I like what Californiadad did in his use of the AEM water/methanol system. Their predetination fail-safe system is pretty effective from several viewpoints and worth checking-out if you haven't already.
Old Jun 5, 2013 | 02:33 PM
flycivicsi's Avatar
Thanks for the input. I was fortunate with this car.. The previous owner repainted the whole car and put new OEM honda inner and outer quarter panels in.. The receipt for the paint was $6000 and the quarters were $4000.. So I should be set there.
Old Jun 5, 2013 | 11:40 PM
peaceable's Avatar
It's a gorgeous EG. Mine's still just a rolling chassis receiving suspension, break and steering parts at this point before I address all of the body and paint issues. Believe it or not, it's trip back to restoration/race, from where I bought it new in 92 and after receiving all of the battle damage over the years, is starting at a much better place than the EJ did. I'm close to the first number on my that sub-project and ought to come-in just under it on that on the completion of paint. It's never been as straight as it is now. One thing at a time for this simple man.
Old Jun 7, 2013 | 02:51 PM
flycivicsi's Avatar
UPDATE:
This project may be taking a little longer then anticipated. The person I had bought the motor from failed at shipping it correctly and the motor never made it to my house. I was at 40 days since purchasing the motor and still have not received it. Nor will I unless I wanted to anti up another $800+. The seller offered me a refund but then later told me he was unable to do so. I have since put in a claim with paypal and am currently out thousands of dollars.. ugh...
Old Jun 7, 2013 | 03:05 PM
peaceable's Avatar
UPDATE:
Oh man, that sucks!!!!!!!!! Was it an eBay purchase from out of country?
Old Jun 7, 2013 | 05:49 PM
flycivicsi's Avatar
It was an HT purchase...
Old Jun 7, 2013 | 07:55 PM
$MIKE$'s Avatar
damm dude that sucks
i though you had a motor for sale on here not to long ago.
Old Jun 8, 2013 | 09:07 AM
flycivicsi's Avatar
Yes, I sold the b20 a month or so ago.. It wasn't what I was after. I have decided if I cannot get this issue with the current motor sorted out I am done with Hondamarketplace... just in the last 8 months I have been ripped off 5 times. I know everyone says do your research, and I look into a person as much as I possibly can, but still get fucked.
Old Jun 8, 2013 | 05:43 PM
phaphon's Avatar
damn sucks that's why I been scared to buy stuff from there
