EFI TUNING SCHOOL
Old Dec 16, 2003 | 10:00 PM
EFIGUY's Avatar
Default EFI TUNING SCHOOL
Hey Guys,
The best place in the USA to learn about engine tuning using fuel injection:
"EFI 101" is back in town again in Huntington Beach, CA on Jan 17-18th.
This seminar will be at the same place as the last...... AytoWave, Inc
For details check out the schedule page at http://www.efi101.com
The seminar is updated and new information has been added, so look for this to be the best one yet!
See ya there!
Old Dec 16, 2003 | 10:02 PM
SiRkid's Avatar
Default Re: EFI TUNING SCHOOL (EFIGUY)
still debating whether or not to go to the april/chicago event
Old Dec 16, 2003 | 10:05 PM
enginetiks's Avatar
Default Re: EFI TUNING SCHOOL (SiRkid)
stop debating...It's well worth it
Old Dec 16, 2003 | 10:17 PM
earl's Avatar
Default Re: EFI TUNING SCHOOL (mschvs)
Nothing is more beautiful than Chicago in early April
Old Dec 17, 2003 | 03:14 AM
TrueNorthStar's Avatar
What joy this brings me!
I missed the last one due to SEMA, this one I won't miss!
Old Dec 17, 2003 | 05:02 PM
EFIGUY's Avatar
Default Re: EFI TUNING SCHOOL (TrueNorthStar)
cool, see ya there!
Old Dec 17, 2003 | 06:32 PM
incogNitto's Avatar
I'll be there - what hours do the classes run? I'm trying to work out travel arrangements.
Old Dec 17, 2003 | 07:16 PM
SiRkid's Avatar
Default Re: EFI TUNING SCHOOL (earl)
yes there is ..toronto
ahahha.
Old Dec 17, 2003 | 08:09 PM
HXMan's Avatar
How much is it for the chicago event?
Old Dec 17, 2003 | 09:01 PM
DA-MAX's Avatar
EFIGUY, any idea when or if even EFI101 is coming back to the mid atlantic area(ie NJ, NY, PA, etc.)?? just wondering before I commit to the session way up in CT in March?? can't wait though
Old Dec 17, 2003 | 09:23 PM
SiRkid's Avatar
Default Re: EFI TUNING SCHOOL (HXMan)
they are all 395 if you sign up now(before jan 31st)
im trying to decide between CT and IL.
CT is a shorter drive for me though(but not by a shitload) so I dunno.
Old Dec 17, 2003 | 10:47 PM
TJ R's Avatar
This is like killing me. I'm half way around the world. And there's an event in April @ Chicago; that's where I studied from 96-02. Always wanted to technically learn more about tuning. I wish I could be there!
Old Dec 18, 2003 | 03:30 PM
EFIGUY's Avatar
Default Re: (DA-MAX)
DA-MAX,
We already have the schedule set all the way through May.......we don't have any scheduled yet for the TRI-State area, but the earliest we will see one there will be july-august ish.......
The $100.00 discount is good only until Jan 31 2004, so don't deliberate too long
Old Dec 18, 2003 | 03:32 PM
Boltz's Avatar
Default Re: (EFIGUY)
im gonna go to the chicago one.
Old Dec 18, 2003 | 03:40 PM
DA-MAX's Avatar
cool beans man, CT it is!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFIGUY &raquo;</TD></TR><TR><TD CLASS="quote">DA-MAX,
The $100.00 discount is good only until Jan 31 2004, so don't deliberate too long</TD></TR></TABLE>
Old Dec 19, 2003 | 09:59 PM
EFIGUY's Avatar
Sweet......see ya there!
-Ben
Old Dec 20, 2003 | 05:46 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Ben, we really need to organize an advanced seminar in the nj-ny area.
Old Dec 20, 2003 | 09:16 AM
EFIGUY's Avatar
Default Re: (SIXTYdashONE)
yeah, I know............yours was the most successful from last year. We are already trying to work on a date, then we'll work on a shop to host the whole deal.....hopefully one that's a bit more Honda friendly this time.......
Also, for the rest of yous guys........
Here is the original seminar outline...it has been expanded now to include more engine tuning theory and actual injection theory.........
What is Tuning?
Calibrating an engine via Laptop
Creating a program that allows the engine to function in a certain manner consistent with the desired application
The process of testing and rearranging the files in a table that commands engine functions of a given nature
Why do we tune?
Maximum performance
power, torque
Drive-ability
Fuel Economy
Throttle response
Ambient conditions change
altitude
temperature
fuel quality
What things in a calibration can we tune?
Main fuel tables
Main Ignition Tables
Boost Tables
Idle Settings
Rev Limiters
How does it all work?
Components, Actuators, Sensors
Theory of Operation (from the process to PV=NrT)
Understanding BSFC and Injectors
What kinds of Modifier Tables do we tune?
Cold Start Extra Fuel
Cold Start Extra Fuel Time limits
Warm-Up Ignition Tables
Warm Up Extra Idle speeds
Acceleration Enrichment
Deceleration Fuel Cut
Altitude and Temp Correction
Battery Voltage Compensation
What Kind of A/F Ratio does the Engine want?
Idle
Part Throttle Light load
Part Throttle Heavy load
Full Throttle N/A
Full Throttle under Boost
Transient Throttle Accelerating
Transient Throttle Decelerating
Injection Timing Relative to crank position
How Do I know how much Ignition Timing the Engine Wants?
Idle
Part Throttle light load
Part Throttle Heavy Load
Full Throttle N/A
Transient Throttle
How to read the Engine's tell-tale signs of performance
Spark Plug color on porcelain
Spark Plug color on ground strap
Piston color on top
Exhaust pipe color
How does it sound
How does it feel
Dyno Tuning or Road Tuning: Which is better?
Dyno provides accurate readings
Dyno is a safe, controlled environment
Road or track tuning can be different than dyno
Dyno won't provide every situation like atmospheric conditions
USE BOTH FOR THE BEST TUNE
Tools of the Trade
Dyno
A/F Meter
Infrared Temp Gun
Spark Plug Light
Standard Test Light
Self Powered Test Light
DVOM
Oscilloscope for experts
Auxiliary Functions
VTEC Solenoid
IAC Valves
Nitrous Solenoids
Boost Solenoids
2 Step Rev Limiter
Anti-Lag Function
Traction Control
Fundamentals of Wiring
What size wire to use?
Solder or crimp?
Use a relay or not?
Covering your wires
Making solid connections with solder
Making solid connections with crimpers
Using the correct connectors
Tuning process from Start to Finish
What Octane will the engine run normally?
Is this the same octane that will be calibrated with?
What is the compression ratio?
Turbo, Supercharger, Nitrous, or N/A
Setting Fuel Pressure
Getting Started and Running
Set Mechanical Base Timing
Tune Engine to Idle properly after warm-up
Tune No-Load RPM sites
Tune No-Load Accel Enrich sites
Begin Part load tuning
Begin Moderate to heavy load tuning
Full Load tuning
Review data logs and power graphs
Make necessary changes
Street or Track testing and tuning
Hope to see ya there!
-ben
Old Dec 20, 2003 | 09:28 AM
HT's Biggest Loser
Yah, I think it was the organizer , jk
Well, we could probably find a different dyno this time, depending on how long we would be there. Whats the outline for the advanced class? I will get ahold of you soon and we will organize something once again.
Old Dec 24, 2003 | 08:11 PM
EFIGUY's Avatar
Looking forward to that!
Talk to ya soon!
for those of you who are inteterested in upcomming classes, check out the schedule at http://www.efi101.com
See ya at the show!
Old Dec 30, 2003 | 04:37 PM
Just registered for this
evoinit
Northeast
Jan 23, 2013 06:01 PM
chinoooooo2008
Engine Management and Tuning
Jan 14, 2011 08:41 AM
freakasis
Aug 23, 2005 07:51 AM
Safir
13
May 5, 2004 06:08 PM
kahlua2323
14
Jun 28, 2002 05:13 PM
