EERR Rod Clearance Issue With ACL STD!?!?!
Old Jul 3, 2009 | 07:00 PM
kreatekustomz's Avatar
Default EERR Rod Clearance Issue With ACL STD!?!?!
Hello all. I have spent most of the day cleaning my block after the machine shop boring it, measuring everything, and plastigauging it.
Well here is what I have and my problem
B18a1 LS crank
Rod Journal Diameter - 1.7708
Golden Eagle Big Bore Dia.- 1.888
ACL STD thickness - .059
So if I do the math 1.8890-1.7708-.059*2 = (.0002") WTF!
Even when I plastigauged it second guessing my mics it was much wider than .001 and seemed to almost be completely smashed...
I'm trying to understand why I'm having problems with my Rod Journal clearance.... pllllleeeeeaaaaaaassssssseeeee give me an idea!
Old Jul 3, 2009 | 07:20 PM
Default Re: EERR Rod Clearance Issue With ACL STD!?!?!
well the more I think about it the more I understand it...
1.8890 - 1.7708 - .059*2 = .0002" (almost no clearance)
BUT if I order oem bearings sized
1.8890 - 1.7708 - .0580*2 = .0022" BUT they dont have bearings that size <---
I just assumed Eagle made their rods or ACL made their bearings to accomidate for one another. But am I right in the assumption that the bearings are wrong?
Old Jul 3, 2009 | 08:14 PM
I just double checked all my measurements
Rod - 1.889
Crank - 1.7708
bearing - .0590
Old Jul 4, 2009 | 06:01 AM
help
Old Jul 4, 2009 | 07:05 AM
IN VTEC's Avatar
The direct measurement and the plastigage measurement corroborate with each other.
What is the specified stretch on the rod fasteners? Are you within the specified range when loading the bolts? Maybe there's too much tension in the bolt.
You could need a HX bearing and possibly a hone of the ID's of the rod big end. I don't think an OEM bearing would give you the clearance you need given that a std-sized ACL bearing was so tight.
Old Jul 4, 2009 | 07:19 AM
Joseph Davis's Avatar
That's an odd one. ACL Race bearings would give you an extra thousandth, 0.0012" is still too tight.
IN VTEC, are HX bearings different?
Old Jul 4, 2009 | 08:12 AM
well I slept on the matter and decided to go outside and forget all my measurments and plastigauge it one more time. I realized that I over tq the rod bolts when I seen there are 3 different types of 5/16th rods one calls for 65 on calls for 75 and one calls for 43. Turns out mine was 43 ft/lbs. So I threw out my first plastigauge reading immediatly and re-did it.
Now I'm withing specifications I believe. I'm a really close if not slightly passed .015.
Eagle calls for .020 rod clearance so I still seem to believe I'm to tight. Would you all like a pic of the plastigauge?
Old Jul 4, 2009 | 08:26 AM
Old Jul 4, 2009 | 09:42 AM
I suppose I could get the crank micro-polished. That would take around ..002-.003 and put me with-in specs?
The other option is to go with Pink OEM bearings and put me closer...
Old Jul 4, 2009 | 10:46 AM
Or ACL Race bearings and introduce an extra 0.001" into the mix. Might be a little cheaper than pinks, and there's nothing wrong with a performance motor being a little loose.
Old Jul 4, 2009 | 01:56 PM
Thats still tight. I would be right at .015 or more like .0155. Anyone see a problem with getting the crank micro-polished? I was reading the cranks service limit is 1.7707 and I'm damn close to that now at 1.7708.
I dont see what the problem is other than Eagles rod bore is to small
Old Jul 4, 2009 | 02:12 PM
No, it would be closer to 0.0021-0.0023", which is serviceable and even ideal for a performance application. 0.015-0.0155" is so loose you'd have oil pressure problems and spin a bearing in short order.
That advertised service limit is the thickness of the crankshaft's surface hardening, which has nothing to do with the real world. As long as you have oil pressure, the bearing never scrapes the crank and a hardened journal surface is irrelevant. Any loss of oil pressure at the power levels a turbo Honda produces will shitcan the crankshaft regardless of a surface hardening. I've been through a number of turned Honda crankshafts that were not re-hardened afterwards and just like everything else that's never had a hardened journal to begin with it works out just fine.
Old Jul 4, 2009 | 02:52 PM
IN VTEC's Avatar
The HX bearings are the ACL Race bearings that provide the extra .001" of clearance. Throw away those rod bolts and buy new ones. They've probably been stretched beyond the yield point and beyond the elastic limit.
I would hone the rod's before cutting into the crank anymore. Micropolishing will only remove a couple tenth-thou's.
Old Jul 4, 2009 | 02:55 PM
Thanks, I didn't know that about the HXs.
Old Jul 5, 2009 | 04:01 PM
Throw away the rods? They are brand new from GE?
I ment if I polish the crankshaft I could get a clearance around .0016-.0018. Seems like .0021-.0024 is a little loose.
Old Jul 5, 2009 | 07:26 PM
Garage 808 Hatch's Avatar
no, throw away the rod bolts, and get new ones, is what he suggested. see what the measurements are on the other ACL options. there's Standard, race standard, and race extreme or some crap. thus giving you 3 thicknesses to choose from.
And to joseph davis. .0015 is TIGHTER that .0021 as it is a smaller clearance, not looser.
Old Jul 6, 2009 | 05:31 AM
Yeah .0015 is tighter but I miss typed the measurement saying .015 which is much looser.
I'm tried to find other thicknesses in ACL but all I can find is the extra .001. Which scares me because of how loose it will be.
I only tq on rod that much. I will replace those rod bolts as mentioned I know I doubled their recommended tq specs..
Old Jul 6, 2009 | 07:16 AM
kyden's Avatar
get an oem bearing?
Old Jul 6, 2009 | 07:24 AM
yeah but I could polish the crank and be right at .0016-.0017 clearance. Which to my understanding is perfect for daily driving. You all think thats a bad idea?
blackeg
Engine Machining & Assembly
13
Jul 12, 2017 03:25 AM
USDM-EK4*
16
Jul 11, 2009 06:05 PM
EGUK
Nov 27, 2006 10:32 AM
reditr
Jan 17, 2004 12:39 PM
ringgold
Apr 28, 2003 02:03 PM
