edelbrock turbo
What do you want to know about it?
It's on of the most comprehensive d-series kits out there, from what I remember. It's good for somewhere in the neighborhood of 200 whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrunkRattlin »</TD></TR><TR><TD CLASS="quote">i think its a waste of money you could peice together your own kit for under 1000 if you want</TD></TR></TABLE>
A turbo setup can be had for less than $1000, but you're going to have to work at that. The Edelbrock kit comes with EVERYthing you need. No searching for fittings, making custom lines, etc.
If you simply want to bolt a kit on and go, then Edelbrock is the kit for you. If you don't mind getting dirty and doing some reasearch, you can go turbo for much less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">A turbo setup can be had for less than $1000, but you're going to have to work at that. The Edelbrock kit comes with EVERYthing you need. No searching for fittings, making custom lines, etc.
If you simply want to bolt a kit on and go, then Edelbrock is the kit for you. If you don't mind getting dirty and doing some reasearch, you can go turbo for much less.</TD></TR></TABLE>
thats what i did, just gettin everything and install now...it is rough
