Ecut or no ecut?
I have h22T and wondering if i should put this 3in ecut on it..or even if it would help. i have a 3in with 2 resinator and a 2.5 maganaflow mufler. not to sure if i want it on there or not. im shooting for 350whp
650cc
t3/t3 60-63
8.5.1 comp
thoughts/comments
650cc
t3/t3 60-63
8.5.1 comp
thoughts/comments
a 2" ID resonator is definately gonna hinder your goal. Ideally no portion of your exhaust should be less than 3".
So yeah the ecut would be better than your current arragement but most would choose a full 3" exhaust over either.
Yeah, honestly I wouldn't run an ecut as its just one more thing to fail...
But if I were going to run one I would probably set it up on a throttle switch so it would open any time I was 60-70% throttle or so.
This way you could tune correctly for part throttle (closed) and WOT (open) and have the tuning be good all the time.
Actually I think some tuning software can be wired to turn extra ish on and off.
with my setup would it be possible to get close to 350whp. i guess its not that big of deal, but i dont really want it super loud.
IDK, you'll just have to search up sme h series set ups, see whose making your goal whp and what they're running. I'd be willing to bet none are under 3".
I would rather my car were quieter as well, but I am not gonna trade any hp for it.
I'll be running a ecut with my setup. My buddy has been running a ecut for a year and he has no problems. My reason for running an ecut is I'm running the stock Honda exhaust and muffler, but use the ecut for track. It's quiet in town, but makes the extra power at the track.
Over the last 3-4 years I've ran different combinations and I had a 3" qtp cutout and within 4 months it crapped out on me. So off the DP I we made a manual cutout out the driver front bumper and my tuner loves the power gains it gives. I run a custom 3" exhaust all the way back with a 3" muffler and when I open my cutout on the dyno with no additional tuning I picked up 33whp with no exhaust. Keep in mind with a open Dp/cutout your car will run leaner and capped will run richer. I love the gains and it sounds mean...........
tune w/ ecut out open. when u close it, the part throttle a/f wont be dat much different, just slightly richer. i had an e cut out on my lsvtec w/ gt3582R turbo, running to a stock muffler. i tuned it with the e cut out open. with it closed at part throttle, the a/f was pretty much the same as it was with it open. at WOT, its a different story. from mid 11's a/f in boost with the cutout open to mid 10's with the cutout closed.
The whole point of running a cutout is to have a quick/quiet car, as well as a fast/loud car. The richer AFR's when its closed won't hurt, you just won't make as much power.
Ideally you'd have a program like Neptune/ECtune that uses dual fuel/ign maps, and switches to them based on an input. I made my own, and it's automaticly opened at 75% TPS, as well as automaticly switches to the 2nd set of fuel/ign maps.
This is what I was getting at.... good tuning closed, good tuning open.
I'm runnin it because it allows me to keep my sanity around town, then unleash the wrath when I want to. I wouldn't own one of these without an e-cutout....one of the best mods to have in my opinion.
and its a night and day difference between closed and open...esp w/ the stock exh...id easily say i shaved about 5-800rpm off my spool times w/ the cutout open
it is unfortunate i had the same idea as you did and had planned to do it but i have never seen it end well. either sticks open or sticks close, motor gets dammaged ect. one thing i did see that looked somewhat promising was https://honda-tech.com/forums/showth...me+made+cutout obviously it would need to be a cleaner version and an electric motor connected to it but i think he was on the right track as far as fixing the binding issues
VSBB6
Jun 6, 2005 07:22 AM
StinkyTofu
Apr 17, 2003 05:50 AM
