ECU Chipping + components
Old Jun 1, 2003 | 08:49 AM
Hybrid's Avatar
Default ECU Chipping + components
When a honda ecu the chip that goes in location -IC4- do I need a chip with the exact code thats on the board -74HC373- or can I be off a few numbers. I.E. the numbers on the chip I'm using are 74LS373N.
Think this would cause a problem?
Old Jun 3, 2003 | 05:11 PM
Hybrid's Avatar
Default Re: ECU Chipping + components (Hybrid)
bump for help
Old Jun 3, 2003 | 11:46 PM
Joseph Davis's Avatar
74LS373N is the same general item as 74HC373(the N is implied - regular 20 DIP).
LS chip is a low power item - uses the same voltage as HC, and can be used in place of it, but draws less current. It will work just fine.
honda_boy23
Sep 16, 2010 02:11 AM
R6Elmo
Aug 31, 2003 05:22 PM
au-gsr
Mar 14, 2002 12:38 PM
