Eagle Rods vs Crower Rods?? Which are better?
From: WTF DC Racer No Way Turbo Washington., DC, USA
I am now hearing that Eagle sells strong rods like Crower which run around $500 is that true. I know that Golden Eagle sells eagle rods.
Reason I am asking this is because my block has been decked out by them and sleeved and I am ready to buy my rods.
GE already has the Eagle rods out and they are makng the crower ones.
Who has broken a Eagle rod?
Engine will be seeing over 23+ of boost?
Any up's and down's.
Sav and Jen williams broke some. Do I like them, yes. I dont plan on making 600+whp, so they will work. I think around 700whp they start to flake.
Manley makes some good strong rods:
does eagle sell 2 types of rods? or one type. I do not plan on making more then 600? How much do the manley run at?
I need custom rods for my deckplate as well. Im gonna give GE a call tomorrow.
[Modified by tony1, 5:37 PM 11/17/2002]
But for me Im gonna only be running with tops 300 whp, And only 15 psi, is it worth for me to get aything better than eagle? Eagle and Golden eage are the same thing right? Whats th best price youve seen for darton sleeves for an h22a4? Where? And how much does it cost to install the sleeves?
First of all, if you setup is done right you will make well over 300whp at 15psi. Second, Eagle and Golden Eagle are two entirely different companies. Golden Eagle sells eagle rods but they aren't the same company. However, you should contact Golden Eagle about getting your block sleeved.
HEy Tony1. Are Darton sleeves know to sith stand up to 18 lbs on a 350+ hp set up? It seems as though when u go Darton u r cutting corners and just trying to savemoney. Is that so?
Golden Eagle and Darton are both excellent, very high quality sleeves. I personally am going to be having Viren do my block for me after i pick it up at osaka in late january. I'll be going with Golden Eagle sleeves, but like i said both GE and Darton are very very very fine companies for sleeving.
Darton sleeves are as good as any. I believe they have a cheap version too, but again, if you're gonna spend that much money already you might as well get the good ones. What it really comes down to with darton is the installer. Golden Eagle only sells their sleeves with installation so you know they will be installed right. When you buy darton sleeves you are relying on the machine shop who installs them. I have had a few problems with local machine shops doing bad installation on sleeves and I won't let it happen again. So, my recommendation, use a reputable machine shop and get whichever sleeves you choose. Golden Eagle, AEBS, and RS Motorworks are the top choices in my opinion and you shouldn't have any problems with any of them.
how much does golden eagle charge for sleeves installed on an h22a4 and how long will i be without my block?
contact viren (member name b18bturbo) or visit http://www.vsracingparts.com for a really good deal on GE sleeving.
Thats what i I stressing about day in and out. I was gonna be scared of having to blame the machine shop for the exploding of a sleeved block. I think im deffinately gonna go with GE.. thanks alot Tony...
