Eagle Rods rod bolt torque???
Old Oct 20, 2002 | 03:55 PM
Boostless97Lude
Guest
Posts: n/a
Default Eagle Rods rod bolt torque???
i've got a set of Eagle rods for my H22, somehow when i was cleaning the shop before i started assembling the enigne, i misplaced my sheet with the torque specs and tightening insruction for tightening the bolts. if anyone has their sheet, or can post a the information listed on the sheet, or a picture of the sheet, i would be unbelievably greatful you. please guys, i know that was a stupid thing to do, but i need the info please.
Old Oct 20, 2002 | 06:07 PM
Farnsrocket's Avatar
Default Re: Eagle Rods rod bolt torque??? (Boosted97Lude)
I am not sure what size the H22 is, but here is what my sheet says:
Use ARP moly assembly lube only!
Bolt - Identification - Torque
7/16" ARP 8740 - 7/16" bolt head - 63 ft lbs
7/16" ARP 2000 - 7/16" bolt head - 75 ft lbs
7/16" ARP L-19 - 1/2" bolt head - 79 ft lbs
3/8" ARP 2000 - 7/16" bolt head - 43 ft lbs
5/16" ARP 2000 - 3/8" bolt head - 28 ft lbs
Old Oct 20, 2002 | 06:38 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Eagle Rods rod bolt torque??? (Farnsrocket)
i'm pretty sure the sheets are all the same, and the bolts already had the lube on them.... thanks a lot, i really needed that
that's twice i owe you for so far
Old Oct 20, 2002 | 06:42 PM
Old Dec 24, 2005 | 08:05 AM
DelSolDon's Avatar
BFTD
i have some Eagle D-series H-beam rods (CRS5394H3D). the bolts have a 7/16" bolt head and are stamped with ARP 2000. however, i am not sure if they are the 3/8" size bolt (43 ft. lbs.) or the 7/16" size bolt (75 ft. lbs.) though. from what i've read, it seems like it should be the 3/8" size bolt but i keep getting confused with the old posts about Eagle's old rod bolts. thanks.
Old Dec 24, 2005 | 11:02 AM
asubennett's Avatar
Default Re: Eagle Rods rod bolt torque??? (DelSolDon)
Are you sure these rod bolt torque #'s are correct. I know for B-series they are far less. 75ftlbs sounds like head bolt torque specs.
Old Dec 24, 2005 | 12:25 PM
earl's Avatar
no honda rod uses 7/16" diameter bolts
Old Dec 24, 2005 | 03:05 PM
USDM 4G VTEC's Avatar
Default Re: Eagle Rods rod bolt torque??? (Boostless97Lude)
Old Dec 26, 2005 | 12:39 PM
DelSolDon's Avatar
Default Re: Eagle Rods rod bolt torque??? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">no honda rod uses 7/16" diameter bolts</TD></TR></TABLE>
exactly what i was looking for, thanks.
EGUK
Oct 24, 2006 10:03 AM
B18C Turbo
Aug 8, 2006 09:41 AM
pentaq
Jun 21, 2006 08:33 AM
foumer
Mar 15, 2006 02:42 PM
blufke
Feb 19, 2004 08:05 AM
