eagle rods any good?
#26
Re: eagle rods any good? (Ltech)
What turbo are using? how big is the i/c? I don't care if you are making 650hp but you can't put it to the ground, that is just wasted power. Care to share us your set up? Anyway, good luck. I'm in the same boat like you are. I've invested 17g in it.
#27
Re: eagle rods any good? (autoEXturbo)
Have you guys ever really put an Eagle rod next to a Crower or Manley rod? Look at the difference between the rod bolts of Eagle and Crower. Measure the quality between the rods in the critical areas. You will see why the American made Crower and Manley rods are more expensive and worth it if you are going for all out power.
#28
Wow.. sounds like a crazy setup.. Other people already asked.. I'm assuming your swapping in a b motor instead of sticking with your d motor?
Also, running 9's is not very likely unless you lighten the car alot = not street legal.
Good luck.
-Mike
Good luck.
-Mike
#29
Re: eagle rods any good? (SlowTeg)
Good luck.
-Mike
Good luck.
-Mike
#30
Re: eagle rods any good? (accordfreak)
i never really got an answer for my f22 engine awhile back..... does eagle make rods for the f22? if not, can they make custom rods for my f22b1???
Give Rocket an instant message on this board. He can set you up with some Eagle rods for your f22 with a custom piston setup.
#32
Re: eagle rods any good? (hondaswaper)
i wouldnt be caught dead with eagle rods........they are made in china ......
#33
Re: eagle rods any good? (ekb18c)
Eagle rods are good man! They can hold the power, and the metalurgy of the rods are pretty good. By the way they are made in Tawian, not china. The labor for the rods are done in Tawian, the materials are from china (the metals).
#35
Re: eagle rods any good? (sparkz)
thanks!
