eagle rods any good?
Old Aug 16, 2002 | 07:25 AM
fastludeh22's Avatar
Default eagle rods any good?
there coming brand in the box, w/an h22 im buying. i want to go around 15 psi on the street and who knows at the track. will they hold up? they say there good for 600+ hp is that true?
Old Aug 16, 2002 | 07:28 AM
justagsr's Avatar
Default Re: eagle rods any good? (93ludevtec)
yep, many can attest to this. For the price you can about buy 2 eagles for 1 crower. jmo and about everyone elses.
Viren (b18bturbo) will tell you after he gets back from his race this weekend.
teho (to each his own). peace
<~~~going to be running eagles with "some" boost
Old Aug 16, 2002 | 07:30 AM
Mase's Avatar
well yes eagle rods kick ***. However, im no prelude genius, but I've heard H22 motors are fickle when it comes to FI. Just make sure you get some beefy pistons to go along with those Rods
autoEXturbo's Avatar
they are awesome, i'll be pushing 14psi on the street and 25psi at the track, they will hold.
Old Aug 16, 2002 | 07:32 AM
justagsr's Avatar
Default Re: eagle rods any good? (autoEXturbo)
good to hear.
Old Aug 16, 2002 | 07:48 AM
Finest's Avatar
It's not the rods that is in question, it's the STOCK piston ringlands. So you'll need to run forged pistons. But in order to run forged pistons, you'll need to resleeve your block. After that would you be able to run 15psi+. Better be prepared to drop a bucket of $$$ into a reliable FI setup.
Old Aug 16, 2002 | 07:52 AM
Default Re: eagle rods any good? (Prelude_RCR)
unfortunately, with speed, money is a key factor. I won't say everything that i'm doing, but i'm spending close to 20k to get my car close to single digits. The car is a coupe and it will be a fully loaded car. Don't let the figure scare you away, when the shop told me i almost said screw it. But my motor will be able to handle upwards of 700hp with a standalone and i'll be pushing about 300hp on the street and 400 at the track.
Old Aug 16, 2002 | 08:20 AM
Mase's Avatar
400 whp will most likely not get you close to the single digits. but im guessin you are ditching the ex motor?
Old Aug 16, 2002 | 08:28 AM
ekb18c's Avatar
Eagle rods can hold! They can hold the power. They are the bang for the buck!
Old Aug 16, 2002 | 08:35 AM
austrian type-R's Avatar
Default Re: eagle rods any good? (ekb18c)
Testing the rods out every day with 1.2 Bar of boost.
Old Aug 16, 2002 | 08:40 AM
ajabbar's Avatar
Default Re: eagle rods any good? (austrian type-R)
Yeah the h22 was not made for no forced induction, so I would sleeve it if your really planning on putting this car to work. imo just get every internal part they make from a good aftermarket company and you will be set not have to be worrying about anything.
Old Aug 16, 2002 | 08:44 AM
D-Man's Avatar
I heard from a couple of diff sources that the eagle H beams can easily handle up to 500hp.
Old Aug 16, 2002 | 08:52 AM
93LSivic's Avatar
Default Re: eagle rods any good? (D-Man)
Viren does in fact run the eagle rods in his race car. He was putting down somewhere around 640 hp i believe. Im not sure exactly what is done to the new motor, if he is even running it.
But yes the eagle have seen over 800 hp on some cars.
I myself cant wait to get my crowers in my motor
Old Aug 16, 2002 | 09:41 AM
Default Re: eagle rods any good? (CDooMe2)
your right, i won't pull a straight 10 second pass, but i have a guarentee(spelling) that she will see low 11's high 10's. My block will handle around 700 hp, so if i want to go to a standalone, she'll see 9's. I want to keep her street legal, and i'm pushing thoughs boundaries with this new setup.
Old Aug 16, 2002 | 09:45 AM
Mase's Avatar
Its just not about adding a standalone my friend, but anyhow good luck
Old Aug 16, 2002 | 10:04 AM
speshuled619's Avatar
eagle rods= without a doubt
Old Aug 16, 2002 | 10:07 AM
prelude rcr, i guess you remeber my other post about the stock pistons. yea i took everyones' advice and im getting it sleeved. also im going w/eathier je or wiesco's.
everyone else, thankx for the input, swayed me more towards keeping the eagles, just kind of still thinking about crowers.
Old Aug 16, 2002 | 10:12 AM
Well that's the only thing the shop said would need to be done in order to get me there. This is not a small setup i'm doing, i'm going all out and doing it right this time. I don't think inline pro has a reason to lie.
Old Aug 16, 2002 | 10:17 AM
Mase's Avatar
first there is this little thing called traction, then once you get that...then you run into the problem with breaking ****, like axles. anyways, i dont have time to go in detail, but i would do a little more reading before suggesting all you need is a standalone. I have a standalone, and im no where near 11's. what turbo are you going to use...for sure not that greddy mitsu
Old Aug 17, 2002 | 10:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: eagle rods any good? (93LSivic)
Try 730whp on eagle rods.
Old Aug 17, 2002 | 11:09 PM
Smashback's Avatar
He said he's spending 20k, so I damn sure hope that includes some strong axles, traction bars, etc. It should not cost that much just to build a motor. If it does, he should have bought some Spoon engines in bulk instead and two bottles, the big ones
Old Aug 18, 2002 | 06:47 AM
Ltech's Avatar
What turbo are using? how big is the i/c? I don't care if you are making 650hp but you can't put it to the ground, that is just wasted power. Care to share us your set up? Anyway, good luck. I'm in the same boat like you are. I've invested 17g in it.
Old Aug 18, 2002 | 11:28 AM
paulzy's Avatar
Default Re: eagle rods any good? (Ltech)
Eagles are not taht great....I shattered 2 of them when I was on the peak of my redline at the dyno. I made 682whp at 9600rpm's and they shattered on me.
just kidding guys
[Modified by paul_vang, 12:29 PM 8/18/2002]
Old Aug 18, 2002 | 12:31 PM
SiR Kid's Avatar
New User
Default Re: eagle rods any good? (paul_vang)
Trade Secret: Eagles have a higher QC standards than Crowers...
Flame me all you like, I think Crowers are just getting too big for their britches. They ask $600 a set, and they don't hold up to the power that Eagles are handling.
Eagle will forever be in my motors.
Best bang for the buck by a MILE.
Old Aug 18, 2002 | 02:44 PM
accordfreak's Avatar
Default Re: eagle rods any good? (SiR Kid)
i never really got an answer for my f22 engine awhile back..... does eagle make rods for the f22? if not, can they make custom rods for my f22b1???
