eagle crank- do I need one???
Old Feb 25, 2006 | 08:00 AM
mec. pedri's Avatar
Default eagle crank- do I need one???
i currently have 672 hp from my ls\vtec at 28 psi. Building new motor for more boost and power (35-40 psi gt42r) . Should I use an aftermarket crank or would the stock one be just fine??
Old Feb 25, 2006 | 09:43 AM
earl's Avatar
Default Re: eagle crank- do I need one??? (mec. pedri)
OEM crank will work fine...they are better than the Eagle crank anyway.
Old Feb 25, 2006 | 12:48 PM
archmage's Avatar
Default Re: eagle crank- do I need one??? (earl)
Why would you say the OEM crank is better than the Eagle Crank?
I know the OEM crank will work fine, but I didn't realize the Eagle crank wasn't even as good!
What would be the best option for a stroker crankshaft then? I know Eagle makes a 95mm crank (and also a lightweight 95mm version).
Old Feb 25, 2006 | 12:56 PM
kylemarhx's Avatar
Default Re: eagle crank- do I need one??? (archmage)
crower.
Old Feb 25, 2006 | 03:58 PM
non-VTEC's Avatar
i would stick with the OEM crank.......if you absolutly had to have a stroker crank crower would be the best choice.
Old Feb 25, 2006 | 05:23 PM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">OEM crank will work fine...they are better than the Eagle crank anyway.</TD></TR></TABLE>
Old Feb 25, 2006 | 05:26 PM
MR.M's Avatar
VTC#2
May 23, 2013 02:28 PM
FEDONV8
Dec 6, 2011 03:24 PM
vipcivic
Dec 25, 2008 07:49 AM
sour97
Sep 30, 2007 05:05 PM
cyrix12
Aug 14, 2005 07:02 PM
