E85 or not???? cant make up mind
Old Nov 5, 2008 | 10:24 AM
  #26
haloae's Avatar
Default Re: (96 GSR-T)
im going to give it a try when i get some free time to tune
anyone have any tuning tips that could help me setup a street tune be4 i get money for the dyno? like what a/f does it do best at under boost and i have heard a lot of talk about timing with e85
Old Nov 5, 2008 | 11:25 AM
  #27
96 GSR-T's Avatar
Default Re: (haloae)
run the same A/F that you would tune to with gasoline, I am by no means a tuner but I have done a good amount of A/F adjustments on my own car, which I have sitting in the 11.5 area at 20+lb.
Old Nov 5, 2008 | 02:18 PM
  #28
BDaTurboTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
my pump is 1000 feet from my front door only one in my state too </TD></TR></TABLE>
lol lucky bastard well we all know what ur choice will be
Old Nov 5, 2008 | 05:57 PM
  #29
92TypeR's Avatar
FSAE
Default Re: (BDaTurboTeg)
E85 is hard to beat for its performance/dollar ratio.
The only downsides IMHO are the decrease in fuel efficiency and (depending on location) availability.
As far as materials go, ethanol promotes oxidation sites on aluminum, forming aluminum oxides that can chew up valveseats and cause some interesting deposits on exhaust valves. Natural rubber is also a no-no with any organic solvent, but is hardly used in any fuel lines anymore. There is a good writeup here on H-T about E85 compatibility, can't seem to find the link right now...
I am doing my senior thesis on switching our Formula program over to "flex fuel". We are using a DTA-FAST ECU (S80-Pro) that has support for the GM Ethanol/Alcohol sensor, so it can continuously adjust fuel delivery and ignition advance depending on the alcohol content in your gas tank.
http://www.dtafast.co.uk/index.shtml
Old Nov 5, 2008 | 06:29 PM
  #30
Glock17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haloae &raquo;</TD></TR><TR><TD CLASS="quote">im going to give it a try when i get some free time to tune
anyone have any tuning tips that could help me setup a street tune be4 i get money for the dyno? like what a/f does it do best at under boost and i have heard a lot of talk about timing with e85</TD></TR></TABLE>
are you going to be running striaght e85 or mixing it? Because right now my talon is tune with e85/93 running 25lbs of boost and i'm loving it.
BoostedDOHCGSR
Jun 6, 2013 04:00 AM
Bonestock98GS
Mar 27, 2010 03:08 AM
oneludesol
Apr 16, 2008 12:44 PM
boostedteg4dr
May 2, 2007 12:01 PM
TurboR1391
Jun 8, 2006 07:48 PM
