E85 Any information on properties & setup?
Old Nov 3, 2006 | 11:21 AM
purpleh22's Avatar
Default E85 Any information on properties & setup?
I have seen a few stations locally that are carrying E85.
I'm currently running C120 - (113 octane) race gas in a fully built 10:1 comp., H22 hatch. I use 10 psi and 17 psi boost settings.
Any idea what octane level E85 would compare to? What AFR should I use at the boost levels I'm using?
It would be a lot cheaper than race gas and would probably be cleaner and cooler if it would work.
Old Nov 3, 2006 | 07:13 PM
komat's Avatar
Default Re: E85 Any information on properties & setup? (purpleh22)
you would need a new tune for e85
Old Nov 4, 2006 | 09:56 AM
quicksilver1689's Avatar
i ♥ snails
New tune, prolly a new fuel pump because u have too supply about twice as much E85 compared to staight gasoline in terms of air-fuel ratios. You need to make sure you fuel lines can handle E85. Theres alot of other things. Im just a noob when it comes to E85
Old Nov 4, 2006 | 11:05 AM
BoostedJeff's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote"> You need to make sure you fuel lines can handle E85. </TD></TR></TABLE>
factory fuel lines can be used with E85. E85= 85% Ethanol, 15% gasoline.
the gasoline is used for its petrolium properties and lubrication factors.
Old Nov 4, 2006 | 12:35 PM
Justin Olson's Avatar
Default Re: (BoostedJeff)
There's a good Power point presentation about e85 here:
http://www.motorgeek.com/phpBB...t=e85
Old Nov 4, 2006 | 01:45 PM
b16hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">
the gasoline is used for its petrolium properties and lubrication factors. </TD></TR></TABLE>
also to keep people from drinking it ha.
I was looking into this a while back because of how much i love ethanol. I believe stoich was around 9.8:1? somewhere in that area, so its not quite double the amount but close.
How much do you pay per gallon for the fuel you run now, i'm running a similar setup to you, and was getting away with 110 leaded @ around 5 bucks a gallon, which was about the same cost as running e85 because of the more fuel used and other upgrades needed (bigger injectors, pump etc..) although you might already have an adequate fuel system so it might be worth it for you
Old Nov 4, 2006 | 02:10 PM
StolenTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">factory fuel lines can be used with E85. E85= 85% Ethanol, 15% gasoline.
Ethanol is corrosion to aluminum and rubber, stock fuel line are aluminum i believe and all the gasket are rubber so it not too safe.
Old Nov 4, 2006 | 02:37 PM
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Ethanol is corrosion to aluminum and rubber, stock fuel line are aluminum i believe and all the gasket are rubber so it not too safe.</TD></TR></TABLE>
which, like jeff said, is why they add 15% gasoline.
Personally when i heard about that, it orginally scared me away from alcohol, but after talking to a few people, one in particular it doesn't bother me much anymore.
This guy runs an all aluminum 500ci blown hemi in a pulling truck (sorry for the non direct example). 100% ethanol through a mechanical injection setup. In the years that hes been running this setup, hes never once had an issue, aside from rubber lines/o-rings. The heads, IM, pistons etc show no acclerated wear
Old Nov 4, 2006 | 03:02 PM
Default Re: (b16hybridsol)
E85
Old Nov 4, 2006 | 04:09 PM
gdh8su's Avatar
Methanol is the one that really corrodes aluminum! They load Ethanol into aluminum tankers to transport to the terminals.
Modified by gdh8su at 8:23 PM 11/4/2006
prj
Jul 9, 2012 08:00 PM
sc4dr
Jan 16, 2011 02:30 PM
adam00
Engine Management and Tuning
12
Dec 22, 2008 07:19 PM
boostedK20a2
Jul 20, 2007 07:24 PM
purpleh22
Jul 11, 2006 08:31 PM
