e-manage or v-afc
Old Apr 26, 2002 | 08:51 AM
RCSIVTEC's Avatar
Default e-manage or v-afc
which do you guys think is better for controlling 440 cc injectors and getting them o idle.
Old Apr 26, 2002 | 09:19 AM
sparkz's Avatar
Default Re: e-manage or v-afc (RCSIVTEC)
the greddy e-manage
Old Apr 26, 2002 | 09:20 AM
RCSIVTEC's Avatar
Default Re: e-manage or v-afc (sparkz)
so then just get the e-manage then will i need any extra hardness or anything else
Old Apr 26, 2002 | 09:28 AM
VTC_CiViC's Avatar
I use an AFC for my 440's, works for me, but I understand the E-Manage will do a better job of it.. just my .02
Old Apr 26, 2002 | 09:33 AM
RCSIVTEC's Avatar
Default Re: e-manage or v-afc (VTC_CiViC)
i was asking because in the new scc issuse greddy has a turbocharged rsx-s with an e-manage and they are using 440cc and some people said they were having idle problems
Old Apr 26, 2002 | 09:57 AM
Ri5e's Avatar
From my understanding, it can adjust up to 20+- ? S-AFc can be adjusted to 50+-
Old Apr 26, 2002 | 10:05 AM
BlueShadow's Avatar
Default Re: e-manage or v-afc (BG Boost)
The E-manages basic features allow you to adjust +/- 20%, but you can have more adjustability with the software and harnesses.
someone said that the e-manage without the software is just like a VAFC, and with the software it is like a full standalone. Too bad Greddy only sells the software to authorized dealers and tuners.
EDIT:
http://www.takakaira.co.jp/performan...age_frame.html
[Modified by BlueShadow, 7:08 PM 4/26/2002]
Old Apr 26, 2002 | 10:10 AM
Ri5e's Avatar
Default Re: e-manage or v-afc (BlueShadow)
Eventually someone will have a copy of it , right? hehe.
Do you know if the e-manage adjusts air/fuel depending on boost/load conditions? Because with the S-AFC, it can't read boost/load so its not a very efficient method to "tune" a car.
Old Apr 26, 2002 | 10:15 AM
BlueShadow's Avatar
If you click the link above and go to "e-function 4" and scroll down on the bottom part on the screen it'll tell you about the E-manages adjustability.
Map has a total display of 256 points (16 points of rotation axis X 16 points of axial load)
what they're saying is 16 RPM points and 16 boost points.
. https://honda-tech.com/zerothread?id=146748
also a good site to go to would be http://www.dsmtalk.com altough some of them are just quoting info out f the same site I linked to. hopefully someone will get it installed and give a review.
[Modified by BlueShadow, 7:16 PM 4/26/2002]
Old Apr 26, 2002 | 10:16 AM
Ri5e's Avatar
do u still gotta use a Rising Rate FMU with the E-Manage?
Old Apr 26, 2002 | 10:21 AM
BlueShadow's Avatar
no I dont think you use a RR FMU, it should be just like a standalone. you would probably still need a larger than stock fuel pump, and fuel pressure regulator, and obviously larger injectors.
With the software you just input the original injector size and the new injector size.
Disclaimer: all this is from memory so you may want to get a second opinion or check my answers with someone else.
Old Apr 26, 2002 | 10:30 AM
Ri5e's Avatar
So the E-manage uses the stock MAP sensor to read in load? or does it have its own sensor?
civicr97
Jul 23, 2003 10:43 AM
dariusz
Apr 5, 2002 08:14 AM
sagaprelude
Feb 5, 2002 01:16 PM
