Durability of GSR transmission on FI???
Old Jul 1, 2002 | 10:10 PM
magicwand's Avatar
Default Durability of GSR transmission on FI???
I'm getting ready to go FI and I was wondering how much punishment the GSR tranny can take.How common is it for the internals to break?Who and how much to upgrade the internals
Old Jul 1, 2002 | 10:41 PM
Def's Avatar
Def
Default Re: Durability of GSR transmission on FI??? (magicwand)
Haven't heard of the actual gears breaking, even holding tremendous amounts of power.
The most common failures will be axles, then your differential. This is assuming your clutch and pressure plate can transmit that much force to the drivetrain.
Old Jul 1, 2002 | 10:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Durability of GSR transmission on FI??? (Def)
they are very strong. If you go above 600whp then you need like a prodrive or quafe gear set. You do need to worrry about broken axles tho..
art
Old Jul 1, 2002 | 10:51 PM
93LSivic's Avatar
Default Re: Durability of GSR transmission on FI??? (Arturbo)
art
Yep, seen it first hand.....courtesy of Art and the JL team. After the axles are replaced, and the diff, and the clutch---then thats when you need to start worrying about the gearset. Well, not really some people have all that------ok after 600 hp or so. I dont think too many of the typical honda/acura lovers will see those numbers though.
Old Jul 2, 2002 | 08:20 AM
magicwand's Avatar
Default Re: Durability of GSR transmission on FI??? (93LSivic)
thinking of buying one that appears (looking at clutch and press. plate) to be abused but only by 200hp or so
stp_vtec_boi
Aug 19, 2006 07:51 AM
B18C-Hatch
Oct 28, 2002 02:48 PM
B18C-Hatch
Oct 28, 2002 12:37 PM
