Has anyone had problems with the prodrive oil pump gear?
I bought one awhile back so I can put it in when I rebuild my motor. I have an LS block and the oil pump gear is for a GSR, the guy at Prodive said they should be the same size and it will work with my oil pump. But now I have people telling me they make defective products and i should use stock. I don't know if I should return it or not. PLEASE some with the oil pump gear let me know of your experience.....Also do I need a GSR oil pump? Thanks
Re: Has anyone had problems with the prodrive oil pump gear? (AGen2integra)
Yes, you need the GSR housing, the LS housing is too small for the Vtec oil pump gear.
Ben
Ben
Re: Has anyone had problems with the prodrive oil pump gear? (Bnjmn)
i dont know if this is true or not, but someone said LS ppl will need to use a GSR timing belt, is this correct?
Re: Has anyone had problems with the prodrive oil pump gear? (int3gra)
I have only heard good things about prodrive. I have one sitting in my closet waiting for the oil pump to get here. So, it better be good. I have heard accounts of the prodrive lasting where a toda did not.
Ben
Ben
I know this is an old topic, But does anybody know which timing belt to use? I should be getting my motor back on Monday and I would like to have it together ASAP. Thanks in advance, Evan
Timing belt = water pump
ls water pump = ls timing belt
gsr water pump = gsr timing belt
