dump tube theory!?!
Old Dec 30, 2002 | 03:13 AM
R-1303's Avatar
Default dump tube theory!?!
why is that people say you loose horse power from dumping back excess boost back into the down pipe if it is not located 10 inches after the turbo???
Old Dec 30, 2002 | 06:23 AM
accorracer's Avatar
Default Re: dump tube theory!?! (R-1303)
:i would like to know also
[Modified by accorracer, 3:24 PM 12/30/2002]
Old Dec 30, 2002 | 06:42 AM
johnisenglish's Avatar
the rule of thumb is that you won't loose power if it's at least 18 inches after the turbo. You'll also want to try to make it a smooth intersection, like a 45 degree angle as opposed to a 90
Old Dec 30, 2002 | 06:53 AM
Overblown-Teg's Avatar
Default Re: dump tube theory!?! (johnisenglish)
I think it has something to do with the exhaust being very turbulant leaving the turbo.. you need to give it time and room to smooth out the flow. Also most down pipes have hard bends and lots of angles right away.. This hurts flow, so buy taking a chunk of exhaust gas out of the beginning of the dp its like having a bigger dp. Then you add it back in once things have calmed down some. I hope that helps.
Old Dec 30, 2002 | 07:10 PM
R-1303's Avatar
Default Re: dump tube theory!?! (Overblown-Teg)
so i will loose power?? or will the dumping of excess boost just be more turbulant because of exhaust flow? will there be so much turbulance that the wastegate might not even open??
Old Dec 30, 2002 | 08:07 PM
DeepSi's Avatar
i think the answer might be if you reenter the gas back into the exhaust flow early it can create exhaust backup and you will not get as much horsepower. so if you reenter later it will less chance of exhaust backup and the exhaust will enter more smoothly and cause less turbulance.
If that did not make any sense, sorry, get over it
Old Dec 30, 2002 | 08:28 PM
R-1303's Avatar
Default Re: dump tube theory!?! (DeepSi)
any other peopel routing their dump tube back to their dp??
Old Dec 30, 2002 | 08:34 PM
JeremyL's Avatar
what about internal wastegates? aslo why would you even bother having a dumptube?
Old Dec 30, 2002 | 10:18 PM
I Like Boost's Avatar
Default Re: dump tube theory!?! (JeremyL)
i have no dumptube, it just shots out the wastegate. kinda loud at times but daily driveable. with no dumptube make sure your not runnin to rich, you wouldn't want to shot flames at your ac lines, but i dont't have those anyways so i dont worry.
Old Dec 31, 2002 | 02:29 PM
R-1303's Avatar
Default Re: dump tube theory!?! (BEe18SeAONe)
can anybody explain why having dump tube to close to the turbo causes loss of power??
Old Dec 31, 2002 | 02:53 PM
BudaKai's Avatar
He hit it right on the head. Backpressure = BAD
Old Jan 1, 2003 | 12:20 PM
crxhybrid1320's Avatar
Default Re: dump tube theory!?! (tzsir)
Run it open!
No need to run into the exhaust system except to quite it down.
Old Jan 1, 2003 | 12:34 PM
BlueShadow's Avatar
Default Re: dump tube theory!?! (crxhybrid1320)
Run it open!
well if you are environmentally friendly you would run the WG dump back into the exhaust. Because the WG gasses haven't had a chance to go through the catalyst yet.
Old Jan 1, 2003 | 12:49 PM
Default Re: dump tube theory!?! (BlueShadow)
Who runs a cat with a turbo application.
Mine is no cat, no resinator, 3' exhaust with a small muffler.
Old Jan 1, 2003 | 12:55 PM
BlueShadow's Avatar
lots of people do, they just go with a 2.5" or 3" cat.
EDIT: at least those that are law abiding do, did you know it's a federal offense to remove the cat? some states are really strict when it comes to enforcing it and others aren't.
[Modified by BlueShadow, 1:56 PM 1/1/2003]
Old Jan 1, 2003 | 02:08 PM
Elite Hatch's Avatar
Run it open!
Whats a catalyst...
OHHH YAH...thats the thing they have on those all motor cars.
Come on now no turbo cars run cats...unless they dont have anything in them, or they want to lose a lot of HP
Old Jan 1, 2003 | 04:45 PM
b18CT's Avatar
Default Re: dump tube theory!?! (Elite Hatch)
a to loud exaust or dump tube will not give you a chance to ear detonation if it occur!
Old Jan 1, 2003 | 04:51 PM
BlueShadow's Avatar
Default Re: dump tube theory!?! (REVTurbo)
That's why you have all those fancy gadgets and doo-dads to monitor your engine and adjust timing so that you dont detonate.
Old Jan 1, 2003 | 05:50 PM
VerbalKint's Avatar
Someone needs to add a spelling and grammar checker into these forums
Old Jan 1, 2003 | 07:33 PM
MotorMatrix.com's Avatar
I am a bad person
Run it open!
catalyst full exhaust 2.5 inch dump
3inch downpipe out the side of the front bumper
[Modified by MotorMatrix.com, 11:36 PM 1/1/2003]
Old Jan 2, 2003 | 02:51 PM
Default Re: dump tube theory!?! (MotorMatrix.com)
3" turbo back is good for the street or strip
I'm sorry if the cops read this forum then yes I have a cat
Old Jan 2, 2003 | 03:03 PM
BudaKai's Avatar
You don't need a cat if you run with a higher ring package and never see high intake temps. Otherwise I don't use a cat either.
Old Jan 2, 2003 | 05:48 PM
R-1303's Avatar
Run it open!
thats my point i live in cali were it is very strict on smog and plus i hate that lawnmower sound when hitting boost, so what happens if i run it lets say 5in pass the turbo??
Old Jan 2, 2003 | 06:19 PM
blkDOHCsol's Avatar
New User
Run it open!
whats a catalyst?? im running open, its not loud at all
Old Jan 2, 2003 | 06:20 PM
blkDOHCsol's Avatar
New User
Run it open!
how you gonna pass emissions with an external wastegate in cali??
