Dual BOV's
Old Apr 17, 2005 | 06:29 PM
LSEGHATCH's Avatar
Default Dual BOV's
I picked up the newest copy of D-SPORT and in there they had a 600+ whp eg civic. While looking at the shots taken under the hood, I noticed he had two Greddy Type-S BOV's. What is this all about, does it associate w/ high hp setups? I've never seen anything like this.
Old Apr 17, 2005 | 07:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Dual BOV's (LSEGHATCH)
it all comes down to the ammount of air the turbo is moving. if you are still getting surge, the other valve will help it out.
Old Apr 17, 2005 | 07:25 PM
z6's Avatar
z6
rice
Old Apr 17, 2005 | 07:40 PM
quick_DC5's Avatar
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">rice</TD></TR></TABLE>So dual waste gates are rice also I assume?
Old Apr 17, 2005 | 07:46 PM
Civicman86's Avatar
Default Re: (z6)
LOL the most over used word in the automobile dictionary.
Old Apr 17, 2005 | 08:27 PM
wdwalker's Avatar
Default Re: (Civicman86)
maybe because its the most over applied term too... i see more and more of it, it's what gives us import guys a bad name (or on the bright side makes our sleepers even more dangerous )
Old Apr 17, 2005 | 08:40 PM
XSIintegra's Avatar
Default Re: (wdwalker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdwalker &raquo;</TD></TR><TR><TD CLASS="quote"> (or on the bright side makes our sleepers even more dangerous )</TD></TR></TABLE>
Amen
Old Apr 17, 2005 | 08:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (XSIintegra)
amazing how quickly we get off topic isnt it.... 98% of h-t must have ADD
*hands out aderall
Old Apr 17, 2005 | 09:45 PM
pimpintyperintegra's Avatar
this is a common practice on high hp supras and yes it is because of the volume of air they flow...usually they put one bov near the turbo and one near the throttle body to quickly let out all that air
it is not neccesary on most set ups but when you run a very large turbo, a lot of boost, and a lot of power it can be helpful...on a 600whp civic he could run one tial or something else larger than a greddy type s but either way works
Old Apr 17, 2005 | 10:40 PM
erau_pilot's Avatar
Default Re: Dual BOV's (pimpintyperintegra)
dual bov's are for looks
Old Apr 17, 2005 | 11:01 PM
SOHC4life 96's Avatar
Default Re: Dual BOV's (erau_pilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">amazing how quickly we get off topic isnt it.... 98% of h-t must have ADD
*hands out aderall</TD></TR></TABLE>
How many kids with ADD does it take to change a light bulb?..................................
Wanna go ride bikes?
&lt;====Has ADD, hence why my HW didn't get done tonight.
Anyways, back on topic. (Sorta) What is the point behind 2 wastegates? I'm guessing its a similar concept behind 2 BOV's.....
Old Apr 18, 2005 | 01:45 AM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erau_pilot &raquo;</TD></TR><TR><TD CLASS="quote">dual bov's are for looks</TD></TR></TABLE>
not in all situation
different BOV"s are good for different applications.....
say, someone has a 400whp supra, and they are running an HKS SSQ...ok, that's fine
now, they toss in some 272's and an EMS and a PT88......you tink the BOV is gonna work fine now at around 1000whp? nah...it won't. well, options are either going to something like the huge Procharger BOV or something like a turbonetics Godzilla....and spending about $400...or just get another HKS for like $150 off someone.....and spend the other money on some race gas
Old Apr 18, 2005 | 07:38 AM
SPOOLINmatt's Avatar
Default Re: Dual BOV's (rhd)
call me rice after i get my new engine done ill be running 400whp-450 whp but if someone has a good deal on another HKS, ill install it too!
Old Apr 18, 2005 | 07:53 AM
Emshhh's Avatar
i dont think it's rice at all... you guys get 600hp and see if a single greddy type s can handle all that air!!
maybe he likes the squeaky noise it produces, so he just got another one.
it's kinda the half *** way to go because he could have gotten another bigger one to cover for the extra air and just use that one alone... but he just got another bov which serves the same purpose
Old Apr 18, 2005 | 07:56 AM
mrbsponge's Avatar
Default Re: Dual BOV's (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways, back on topic. (Sorta) What is the point behind 2 wastegates? I'm guessing its a similar concept behind 2 BOV's.....</TD></TR></TABLE>
dual wastegates are used for the same thing.
alot of people DONT realize the flow path of exhaust and why wastegate positions are so important. i know alot of EQUAL LENGTH STYLE manifolds have issues with this.
on mine i use a 6psi spring but with no boost controller it runs a perfect 10psi, because exhaust has trouble branching off 90 degrees the opposite way.
so the higher boosted cars, usually above 25psi runsomething like a dual tial 40mm wastegate set up to ensure proper boost regulation, because it is moving that much exhaust ut needs a place to go.
just like using 2 BOVs, it is needed to expell all that air. but if you look at where they are used it is almost always on something more than 500HP. not a 250hp civic
Old Apr 18, 2005 | 08:30 AM
LSEGHATCH's Avatar
Default Re: Dual BOV's (mrbsponge)
Well my setup now took a turn for the upper hp side and I'm thinking about selling my type-s, but when I saw that this guy had dual type-s bov's. So what works for 550 - 600 hp setups, will one ssqv do the job or is there a better alternative. From what I hear, the type-s doesn't have the best sound so whith aggressive sound in mind along w/ performance what works?
Old Apr 18, 2005 | 09:55 AM
wdwalker's Avatar
with 600hp, who really cares what it sounds like? lol
Old Apr 18, 2005 | 10:33 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote"> the type-s doesn't have the best sound so whith aggressive sound in mind along w/ performance what works?</TD></TR></TABLE>
Type S is one of the best sounding bov's ever made..
Old Apr 18, 2005 | 11:05 AM
asylumxl's Avatar
Default Re: Dual BOV's (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">Type S is one of the best sounding bov's ever made..</TD></TR></TABLE>
Now that is a matter of opinion
Old Apr 18, 2005 | 11:36 AM
LSEGHATCH's Avatar
Default Re: Dual BOV's (asylumxl)
Well like I said <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">From what I hear, the type-s doesn't have the best sound...</TD></TR></TABLE>
Also I don't want a gay turkey call bov either...they really irritate me
Old Apr 18, 2005 | 05:15 PM
Emshhh's Avatar
it's all about the 50mm tial bov
aggressive and flows awesome!
sounds like a crack of a whip :D
Old Apr 18, 2005 | 05:26 PM
rhd's Avatar
rhd
tials suck
if you're doing BIG hp...look at:
Greddy Type R
HKS Race
Turbonetics Godzilla
Procharger bov
Vortech mondo? max-flo...i can't remember the big one
Old Apr 18, 2005 | 06:45 PM
powerls's Avatar
he is running 2 because the Greddy type S doesn't flow at all, that is why it whistles. It compresses air into a small area then releases it. Why do you think Greddy has changed the RS noise, because now it actually flows. Just think of it this way, running a mile while whistling vs running a mile with your mouth open.
I have always hated the way the type S and HKS SSQV sounds, never really made me think of power, but that is my own oppinion.
Old Apr 18, 2005 | 07:13 PM
Default Re: (powerls)
I have always hated the way the type S and HKS SSQV sounds, never really made me think of power, but that is my own oppinion. [/QUOTE]
the higher the boost the better the hks sounds, it just dumps the air when its high boost. like a slap in the face.
and for the guy saying TIAL sucks, LOL on you, thats a first for me EVER. my tial 35mm never spikes, creeps, nothing nada, never HAS!!! even with a manual boost controller. EVER!
Old Apr 19, 2005 | 08:47 AM
powerls's Avatar
Default Re: (SP00LIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">
and for the guy saying TIAL sucks, LOL on you, thats a first for me EVER. my tial 35mm never spikes, creeps, nothing nada, never HAS!!! even with a manual boost controller. EVER!</TD></TR></TABLE>
He was talking about the BOV, big guy.
hood ride eg
Southern California
Oct 25, 2008 07:10 AM
toolow69
Jul 10, 2007 12:37 AM
JDMTuner4Life
Apr 26, 2007 06:56 PM
87shytwhip
Oct 25, 2006 12:33 PM
Option-STiK
Feb 22, 2004 06:38 AM
