DSM install... Do i need to modify rubber ring at bottom?
Old Nov 2, 2003 | 03:39 PM
BoostedD15B7's Avatar
Default DSM install... Do i need to modify rubber ring at bottom?
Gonna install some dsm and was wondering if i have to buy a different rubber boot for the bottom. I saw something about getting a different one because of height differences and enlarging the hole...Do i have to do this?
Old Nov 2, 2003 | 03:40 PM
rjardy's Avatar
Default Re: DSM install... Do i need to modify rubber ring at bottom? (BoostedD15B7)
dremel them out a bit. or you can try and shove them in there but its pretty tight.
Rob
Old Nov 2, 2003 | 03:44 PM
TeStUdO's Avatar
The big dremel sanding drum is actually the perfect size. Just leave the o-ring in the manifold and dremel them out, it makes it easier.
Old Nov 2, 2003 | 03:56 PM
luti's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">The big dremel sanding drum is actually the perfect size. Just leave the o-ring in the manifold and dremel them out, it makes it easier.</TD></TR></TABLE>
Good idea, but, not a good idea if the manifold is on the car... I use the top part of a 2 litter soda bottle, also the perfect size :D
Old Nov 2, 2003 | 04:03 PM
Default Re: (luti)
will i have to get different ones or can i use the one on it if they are in good shape? Is the height on them right or will they let the tip sit too low in intake runner?
Old Nov 3, 2003 | 06:20 AM
legendboy's Avatar
Default Re: (BoostedD15B7)
a hammer ownz dsm injector install
Old Nov 3, 2003 | 07:05 AM
ITSTOCK's Avatar
Default Re: (legendboy)
This is how i did it, i put the injectors in the holes just squeezed them in halfway as far as i could get them, put the fuel rail on top of the injectors and put the nuts on teh fuel rail, tightened it until it was tight and when i tightened teh fuel rail nuts it seated the injectors in perfectly. I didnt dremel the seals, waste of time.
Old Nov 5, 2003 | 08:01 AM
Default Re: (ITSTOCK)
can i use the stock honda bottom ring or do i want to use the eclipse one?
Old Nov 5, 2003 | 08:50 AM
2muchPSI's Avatar
homemadeturbo.com
click on "tech projects", they go over the dsm injector install in detail there. It should tell you what you need.
Old Nov 5, 2003 | 10:16 AM
mike1114's Avatar
Default Re: (2muchPSI)
stock bottom honda ring. Do it like itstock said.
Old Nov 5, 2003 | 10:55 AM
BlackKnight7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">can i use the stock honda bottom ring or do i want to use the eclipse one?</TD></TR></TABLE>
I used the stock honda orings. Just find somthing to mount the ring on outside of the car, and take a sanding drum and just lightly take some rubber off, just keep going back and forth from the manifold and sanding until you have just the right fit. You should be able to do it so the slide in w/just a little bit of force.
I just found a piece of circular rod that was the right diameter to mount the
o-rings on then put it in a vice and went to town w/a dremel.
Sanding them in the intake manifold would work, but make sure its not on the car when you are doing this.
Jake d.
blue_hatch
Welding / Fabrication
Mar 3, 2008 09:13 AM
votoms888
May 29, 2007 10:48 AM
GroundZer0 336
Feb 19, 2005 01:56 PM
airwalk07143
Dec 3, 2003 07:37 PM
B18C-RnVA
Nov 17, 2002 03:22 PM
