My Turbo setup In Process *yayay*
Just wanted to share to you guys what I am in the process of doing.
Motor
-LS block with Darton sleeves 84mm bore
-OEM ITR water & oil pump
-OEM b20 headgasket
-Toda Timming Belt
-Arias 9:5:1 piston
-Eagle H Beam rods
-Balance & blue print buttom end
-Blitz sandwich adapter for LSVTEC conversion
Head
-Stock b16 head
-GSR cams
-Skunk 2 cams sproket
-JDM ITR Intake manifold with ITR throttle body
Turbo set up
-Turbonetics t3/t04e stage 2 / .82 AR - 60 trim
-Custom pipping done by Raceline
-Custom 3" downpipe done by Raceline
-Blitz 500hp Intercooler
-HKS wastegate 7lbs spring
-3 " exhuast pipping with 3" muffler
then the rest is the basic turbo accessories , fuel pump etc.. you guys get the point.
Hoping to get 450whp-500whp with this set up, wish me luck!
And if you guys planning on any turbo set up and need help, Hit up Raceline and ask for Elton. He will guide you and help you pick the perfect set up for your statisfaction.
Motor
-OEM b20 headgasket
-Toda Timming Belt
-Arias 9:5:1 piston
-Eagle H Beam rods
Head
-Stock b16 head
-GSR cams
Turbo set up
Re: My Turbo setup In Process *yayay* (30psi Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg »</TD></TR><TR><TD CLASS="quote">good luck sounds like its gonna be a monster.</TD></TR></TABLE>
thanx for the possitive comment. Oh BTW i'll be running on the Inline Pro exhuast manifold lolz forgot to mention that oopz =P
CRXherbie91
11-18-2016 11:34 AM
