DSM injector and misc info (pics)
Old Jan 27, 2003 | 07:48 PM
JT's Avatar
JT
Default DSM injector and misc info (pics)
We all know using DSM 450cc injectors is a cost effective alternative to RC injectors. However, most people have problems installing them due to the the larger physical size of the DSM injectors. Some choose to bore out the stock bottom seals and some choose to the force fit method. Some say the injectors should sit flush to the seal, and some say it shouldn't. Well, I'm hoping the information that I'm about to share will help a little. Certain information may or may not apply to your setup type but I'm sure you'll get the idea.
1. Injectors seals: Napa sells an injector seal kit that contains seals for Civics and Integras. Because I have a Civic, the taller Integra seal works out perfect for me! If you don't need the complete seal kit, just go to Acura and buy only the bottom seal, or try to find some taller seals that have the same outside dia.
2. Bore out the bottom seals: I find it much easier to bore out the seals with a Dremel and do it in the manifold. I simply use a stock manifold that I have sitting around and use it to hold the seals. It only takes seconds to bore each seal!
3. Finished product: If done properly (which is extremely easy), it will look like stock.
4. Injector tip protruding distance: This is the good part. With the properly selected bottom seals, the injector tip protruding distance in the manifold can be the same as stock and still allows the injectors to sit flush on the seals! Btw, the injectors should go on the seals with slight friction.
Stock injectors with seal.
DSM injectors with taller seal.
5. Installed DSM injectors: The injectors fit very nicely in the JRSC intake manifold with the taller seals.
Here's a closeup, nice and flush!
Old Jan 27, 2003 | 07:52 PM
boostaholic's Avatar
Default Re: DSM injector and misc info (JT)
Nice write up
Old Jan 27, 2003 | 07:54 PM
Diego Boost's Avatar
Good **** bro!
Old Jan 27, 2003 | 07:55 PM
J2turbo21's Avatar
Default Re: DSM injector and misc info (boostaholic)
good info
Old Jan 27, 2003 | 08:02 PM
turbod16y8's Avatar
Old Jan 27, 2003 | 08:14 PM
SiRkid's Avatar
Default Re: DSM injector and misc info (turbod16y8)
very awesome
Old Jan 27, 2003 | 08:21 PM
Captain Save-a-Hoe's Avatar
Default Re: DSM injector and misc info (SiRkid)
Thanks for takin the time to do that.
Old Jan 27, 2003 | 08:39 PM
LshatchTurbo's Avatar
New User
Default Re: DSM injector and misc info (Blackie Chan)
Old Jan 27, 2003 | 08:40 PM
Sprockets's Avatar
Nice install!
Oh, and thank you! This is very helpful and informative. What about the size of the stone on the Dremel tool. Is it the standard size that comes with the Dremel?
[Modified by Evil Beaver, 9:54 PM 1/27/2003]
Old Jan 27, 2003 | 09:17 PM
Sonny's Avatar
Strippers for JT!
Sonny
Old Jan 27, 2003 | 09:28 PM
ElectronMan's Avatar
About a year ago when I got my Hondata and DSM 450s, I purchased the same injector seal kit. It works excellent. God job on the write up.
Old Jan 27, 2003 | 09:30 PM
JT's Avatar
JT
Default Re: DSM injector and misc info (Sonny)
Thanks guys!
Old Jan 27, 2003 | 09:31 PM
AbaZ's Avatar
finally a good write up.. mind if we host this at my site?
http://www.homemadeturbo.com
let me know,
Jeff
Old Jan 27, 2003 | 09:34 PM
JT's Avatar
JT
Default Re: DSM injector and misc info (AbaZ)
Sure, go for it! The whole idea is to share informaiton.
Old Jan 27, 2003 | 09:48 PM
TurbothisLS's Avatar
nice pics and nice instructions
how do you guys hid the wiring for the resistor box so well??
also, where to get clips for those injectors?
i'm using some that work, but are kinda loose
Old Jan 27, 2003 | 10:07 PM
UberTeg's Avatar
are you saying the sanding drum is the perfect diameter for the injectors?
Old Jan 27, 2003 | 10:24 PM
JT's Avatar
JT
Default Re: DSM injector and misc info (UberTeg)
The injector body size that goes on the seal is .631" or 16.04mm. The sanding drum that I used is the standard accessory pack that came with the Dremel kit, which is .590" or 14.99mm. When the sanding drum is installed on the shaft and tighten down, the new dia is .608" or 15.45mm. That provides a nice friction fit after the seal is bored out. HTH...
Old Jan 27, 2003 | 11:27 PM
AbaZ's Avatar
Here ya go fellas.. I added a bit of info on the inline resistor install as well...
http://www.homemadeturbo.com/dsm.htm
Thanks JT,
Jeff Frank
[Modified by AbaZ, 8:27 AM 1/28/2003]
Old Jan 28, 2003 | 12:00 AM
BlueShadow's Avatar
Just out of curiousity, does this write-up also apply to H22(A4)'s?
TIA
Old Jan 28, 2003 | 12:49 AM
LJR-LUDE01's Avatar
Default Re: DSM injector and misc info (BlueShadow)
TIA
same as above... and would the same seal kit work on it..? p/n?
Old Jan 28, 2003 | 02:12 AM
MiraiZ's Avatar
Default Re: DSM injector and misc info (LJR-LUDE01)
about time someone showed that!...thanks!!
Old Jan 28, 2003 | 04:21 AM
KingDsi's Avatar
on the write-up!
You can also double up the stock size seals, and it fits perfect also.
Someone else figured out the large dremmel drum bores perfect!
Old Jan 28, 2003 | 06:52 AM
rbf351's Avatar
Default Re: DSM injector and misc info (weakboost)
looks good
all i did to fit mine were use the same green o rings and some WD40 and press them in
Old Jan 28, 2003 | 07:00 AM
VTC_CiViC's Avatar
Default Re: DSM injector and misc info (rbf351)
Looks good!! I'll have to do that for my DSM's when I slap them on the teg!
Old Jan 28, 2003 | 07:09 AM
JT's Avatar
JT
TIA
I'm not sure about the p/n or seal size for the H22. However, just go down to a Napa store and ask for a seal kit for the H22, as well as the kit for the Civic/Integra (use p/n above). Put the seals from the two kits side by side and perhaps borrow a caliper from them to compare the outside dia and height. If they are the same, then you are set. Don't worry about the inside dia because it will be enlarged by the Dremel.
