DSM injecters need help real quick on install
k i got the RESISTER PACK from a accord and injecters from a talon awd turbo 450cc one i wana install them to a 96 GSR MOTOR what do i need to do i tried to install them but the injecter is to big for the stock o ring ....can it still work???????worrying bout leakege our something since they fit a little tight....anyone who has done this setup leme know so i can do it right.........
i think you have to bore out the o-rings a little to get them to fit. most people use the dermel or something like that
-deepsi
-deepsi
yea thats it what horsepower can these injecters handle up to with a afc and a map controller that adds fuel during boost leme know
[Modified by ProJecTRacEr, 9:17 PM 12/12/2002]
so use the stock gsr o rings and there will be no leaks? only 250-300horsepower on 450cc? thought could atleast get 400-450 and the dsm injecters fit kinda higher then stock so do u put washers on the fuel rail?
stock seals should be fine..
I'd go 550 or bigger for that much hp...watch the duty cycle, if its at 80% or higher at WOT...then its bigger injector time!
AudioXtremes
22
Sep 7, 2002 10:08 AM
