dsm big 16g on b16
Old Mar 17, 2005 | 03:56 PM
lone's Avatar
Default dsm big 16g on b16
i have access to a big 16g turbo so that i can turbo my b16. i know that i would have to get a custom manifold for a evo 16g to fit but i can't find any info about the big 16g. what kind of manifold flange will i need?
Old Mar 17, 2005 | 04:07 PM
beepy's Avatar
Default Re: dsm big 16g on b16 (lone)
Mitsubishi TD05 flange, just with a larger inlet. Let's see....
Here: http://www.roadraceengineering...s.htm
They have the inlet and downpipe flanges you will need.
Old Mar 17, 2005 | 04:20 PM
lone's Avatar
Default Re: dsm big 16g on b16 (beepy)
does that mean i can use a greddy manifold since its the same flange as a td05
Old Mar 17, 2005 | 04:24 PM
blown_LS's Avatar
Hmm i'm not sure either whats the flange on greddy turbos but big 16g has mitsu flange also whats your power goals those turbos have made 400whp on dsms so its nasty little turbo.
Old Mar 17, 2005 | 04:29 PM
lone's Avatar
Default Re: dsm big 16g on b16 (blown_LS)
not looking for anything too extreme. its just junkyard kit for my friends teg. we are getting most of the turbo setup off an eclipse.
Old Mar 17, 2005 | 08:16 PM
lone's Avatar
does anyone know?
Old Mar 22, 2005 | 12:18 PM
GPNY's Avatar
Big 16g uses DSM Square flange. NOT THE SAME AS GREDDY which uses T25 flange.
SFP Makes manifolds that work
Old Mar 22, 2005 | 05:59 PM
BLANKS143's Avatar
Default Re: dsm big 16g on b16 (GPNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPNY &raquo;</TD></TR><TR><TD CLASS="quote">Big 16g uses DSM Square flange. NOT THE SAME AS GREDDY which uses T25 flange.
SFP Makes manifolds that work</TD></TR></TABLE>
hes right, they are different
Old Mar 22, 2005 | 07:21 PM
93turbo16's Avatar
that is correct. A DSM turbo will not fit a nissan T25 housing, which is what a greddy turbo uses. I actually have a pic of one.. the only difference is the housing really.
It is the turbo right infront of the box, with a massive port. The housing below is a super 16G and the housing to the left is a ported 16G with a bigger wastegate flapper.
Just some random junk I have laying around.
Old Mar 23, 2005 | 09:35 AM
GPNY's Avatar
Default Re: (93turbo16)
Did you ever use that super 16g (T3 flange btw if it's from hahn racecraft) It so how was spool/power output compared to the EVO3 turbo?
My setup has the Super 16 Td05h 10cm housing (d16z6 77mm 10:1 comp) and I'm a bit worried about spool...
Old Mar 23, 2005 | 04:28 PM
93turbo16's Avatar
Default Re: (GPNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPNY &raquo;</TD></TR><TR><TD CLASS="quote">Did you ever use that super 16g (T3 flange btw if it's from hahn racecraft) It so how was spool/power output compared to the EVO3 turbo?
My setup has the Super 16 Td05h 10cm housing (d16z6 77mm 10:1 comp) and I'm a bit worried about spool...</TD></TR></TABLE>
That is the exhaust side that is going on my stock Z6, so I will let you know then.
Old Mar 23, 2005 | 06:56 PM
lone's Avatar
we're still working on getting a manifold for it. i'll let you know when we get it
crazygringo90
Welding / Fabrication
Nov 2, 2009 03:12 PM
nastynutsnash
Jun 17, 2007 01:25 PM
Soccerking3000
Mar 5, 2004 06:45 AM
2FASTDC2
Feb 4, 2004 06:11 PM
DerekY
Nov 11, 2003 08:59 PM
