DSM 450 injector install ?'s...
Old Mar 31, 2003 | 04:17 PM
TurboJesse
Guest
Posts: n/a
Default DSM 450 injector install ?'s...
Would have done a search if it was working so sorry if this has been asked before....anyways im in the process of intstalling this injectors on my 2nd gen b16a, i bored out the rubber ring so the injectors fit snug in the intake manifold and have the resistor box wiring done...the clip does not plug into the dsm injector, what needs to be done in order to get this working? i was under the impression that obd1 clips worked? please help this is my first time installing injectors and i would love to get it done wiht so i can move on to the rest of the turbo install
Old Mar 31, 2003 | 04:20 PM
ridnmyhonda's Avatar
Default Re: DSM 450 injector install ?'s... (Mpir3)
i think you can buy clips at napa/schucks
Old Mar 31, 2003 | 04:30 PM
tegasaurus's Avatar
I've heard that all you have to do is cut/sand a little fitting inside the clip and it should plug right in.
-Ryan
EDIT: disregard, im thinking of the 9005/9006 integra headlight conversion harness... I'd like to find out also, im in the same situation as you.
[Modified by tegasaurus, 5:42 PM 3/31/2003]
Old Mar 31, 2003 | 04:51 PM
Infinity_Racer's Avatar
Default Re: DSM 450 injector install ?'s... (tegasaurus)
-Ryan
[Modified by tegasaurus, 5:31 PM 3/31/2003]
thats all i had to do with mine...i just used a dremel with a small bit on it and trimmed the little plastic piece on the injector
Old Mar 31, 2003 | 05:48 PM
GOLDBERG's Avatar
Default Re: DSM 450 injector install ?'s... (Infinity_Racer)
what little plastic peice??could someone post a pic??
Old Mar 31, 2003 | 05:51 PM
keebler65's Avatar
Default Re: DSM 450 injector install ?'s... (GOLDBERG)
does anyone know if the DSM's will plug into an OBD-0 harness?
Old Mar 31, 2003 | 06:06 PM
tegasaurus's Avatar
I'd like to know as well
Which one was cut? 1, 2, or 3? (or 4, which is identical to number 1, just on the other side)
-Ryan
[Modified by tegasaurus, 7:07 PM 3/31/2003]
Old Mar 31, 2003 | 06:11 PM
damn you beat me to it with the pics...its number 3, the one inside...and i got another set of injectors and the guy said it has crx clips on them...so i'm guessing it bolted right up cus that little plastic piece wasnt trimmed...HTH
Old Mar 31, 2003 | 06:13 PM
TurboJesse
Guest
Posts: n/a
so if we trim #3 in the pics it should plug right in?
Old Mar 31, 2003 | 06:16 PM
B18Flip's Avatar
into obd2 plugs?
Old Mar 31, 2003 | 06:19 PM
TurboJesse
Guest
Posts: n/a
Default Re: DSM 450 injector install ?'s... (B18Flip)
no i have obd1 plugs
tegasaurus's Avatar
into obd2 plugs?
or obd1 plugs?
thats what i did to mine and it plugged right up...
Old Sep 17, 2003 | 04:56 PM
luti's Avatar
Have any of you guys gotten them to fit on OBD2 plugs? (ie: D16Y8)
martial
Feb 21, 2010 08:34 AM
white98gs-r
May 15, 2009 10:43 PM
MBlake55
12
Jul 2, 2006 03:59 PM
turbotime
May 14, 2006 02:33 PM
Black R
Jun 17, 2004 01:34 AM
