DRAG Intercooler Piping layout???
Old Jun 10, 2002 | 07:14 PM
Teg4e's Avatar
Default DRAG Intercooler Piping layout???
Could someone point me to a link on how to fit together all those pipes for a DRAG kit for the Integra? or, just describe it.....Thanks
Ethan
Old Jun 10, 2002 | 07:20 PM
Flamenco-T's Avatar
Default Re: DRAG Intercooler Piping layout??? (Teg4e)
a small 2" diameter 90deg angle goes to the compressor outlet
a staright the 90 deg then another 90 deg, about 2" in diamter goes from the above pipe to the IC inlet ( the 2" inlet)
the U bend, goes from outlet of IC then the 90 deg rubber boost, then the charge pipe
before IC should be 2", after IC is 2.25"
Old Jun 10, 2002 | 07:21 PM
Etylorcen's Avatar
Default Re: DRAG Intercooler Piping layout??? (Flamenco-NA)
Its like a puzzle for horsepower. Once you start actually doing it it goes pretty easy. If you're just trying to put it together off the car you might have some trouble.
Old Jun 10, 2002 | 08:53 PM
Teg4e's Avatar
k, so what's this 45 degree bend for?
Old Jun 10, 2002 | 08:58 PM
Flamenco-T's Avatar
for the air filter...
it should go like this, compressor outlet, the 45 deg with DRAG stamp on it, then then funky looking piping..they should all be 3" in diameter or 2.75"
ek9vboi2
Mar 2, 2005 08:09 PM
NapTownSi
Feb 27, 2004 04:05 AM
Pritos
Jan 11, 2002 08:45 AM
BoostingGSR
Dec 24, 2001 04:30 PM
