drag III for LS..
Old Aug 18, 2002 | 08:27 PM
geminis2k's Avatar
Default drag III for LS..
What FMU ratio does it come with? WHat other differences are there between the drag III type R and LS kits?
Old Aug 18, 2002 | 10:22 PM
sushibug's Avatar
Default Re: drag III for LS.. (deception23)
all the fmu's drag kits come with will be 12:1. the only way they would go to a smaller ratio would be if they included injectors.. which they wont because injectors are pricey. type-r probably has different piping.. maybe different .ar and what not too.
Old Aug 18, 2002 | 11:13 PM
SIK IN DA HED's Avatar
New User
Default Re: drag III for LS.. (sushibug)
the GSR and ITR piping sit lower where it connects to the throttle body. thats the main difference.
Old Aug 19, 2002 | 11:19 AM
quickspoolin's Avatar
Turbos are differrent also.
Old Aug 19, 2002 | 11:42 AM
JM Performance's Avatar
Default Re: drag III for LS.. (dlplayboy)
no, itr TB and ls TB are in the same position
Old Aug 19, 2002 | 02:00 PM
New User
Default Re: drag III for LS.. (00SilverLS)
u sure about that? one of my race crew members has a ITR and weve already tried to fit my friends drag3 kit on his car and the intercooler piping to the throttle body didnt fit because the manifold sits lower. ill double check again... but im pretty sure the ITR tb sits lower with the manifold.
[Modified by dlplayboy, 3:02 PM 8/19/2002]
Old Aug 20, 2002 | 08:20 PM
Foozball26's Avatar
whats the difference between the 2 turbos?
and how much of a loss / gain would the type r turbo have on an LS engine?
Old Aug 20, 2002 | 08:47 PM
PureTeg420's Avatar
Default Re: drag III for LS.. (foozball-26)
Depending on who you buy the kit through (importparts for example) , all b-series motors use a t3/t04e 54 trim. Also, the LS and ITR piping is indentical.
Old Aug 20, 2002 | 09:10 PM
avividmemory's Avatar
Default Re: drag III for LS.. (PureTeg420)
it sure is, gsr is the odd ball
Old Aug 27, 2002 | 12:44 PM
X2BOARD's Avatar
I had heard the ITR kit brings a diff turbo spec than the LS kit...
OH... and the ITR piping is the same as the LS.
Old Aug 28, 2002 | 08:35 AM
X2BOARD's Avatar
Default Re: drag III for LS.. (94hondahybrid)
Ive heard both but will the turbo manifold off of the type-r/GSR kits fit the LS?
Yeah, the bolt pattern for the LS/GSR and ITRs exhaust manifold is the same, so the same turbo manfold works on all of them. The stock intake manfiolds on all 3 are designed differently, but it's just that the LS and ITR intake mani's are shaped similarly and have the Throttle body positioned in the same location (upward slope) as opposed to the GSRs mani, which is downward slope.
X2
Old Aug 28, 2002 | 09:49 AM
RicerRacing69's Avatar
Default Re: drag III for LS.. (quickspoolin)
No there not, just who you buy them through and if you get larger housing option is diff.
Old Aug 28, 2002 | 09:57 AM
Speed PHreak's Avatar
Default Re: drag III for LS.. (X2BOARD)
The turbo's are the same between GS-R/ITR/LS
T3/T04E
Cold side - 54 trim or 57 trim, can't remember which.
Hot side - .63 A/R w/ Stage III Wheel
Stylinhonda
Mar 5, 2006 03:46 PM
DeL SLo
Mar 13, 2003 07:58 PM
PM-Performance
Dec 7, 2002 11:10 AM
Pritos
Jan 11, 2002 08:45 AM
