DRAG III DOWNPIPE Question
Old Aug 24, 2004 | 08:32 AM
black sohc civic's Avatar
Default DRAG III DOWNPIPE Question
Do I put a bolt/stud in the circle hole or Do I leave it open?
Old Aug 24, 2004 | 08:39 AM
SC61HB's Avatar
Default Re: DRAG III DOWNPIPE Question (black sohc civic)
That hole is used when and internal wastegate is attached. If you're using an external wastegate you don't have to worry about it. The flange that bolts up to it for the dp will block it off.
Old Aug 24, 2004 | 08:54 AM
-Trinitron-'s Avatar
Default Re: DRAG III DOWNPIPE Question (zgrieger)
What he said
Old Aug 24, 2004 | 09:03 AM
I am using an external Tial WG but my DP dosent block it off, it leaves it open. Should I block it off? Reason I ask because I seem to have an exhaust leak, I think this may be causing it.
Old Aug 24, 2004 | 09:09 AM
Rod.'s Avatar
your dp should cover that hole up.
DriveSlowHomie
Apr 19, 2005 02:04 PM
DA-MAX
Jan 29, 2004 05:55 AM
platinum00
Sep 22, 2003 10:39 AM
rrei
Jul 18, 2002 08:06 AM
civbeater90
Jan 8, 2002 02:39 PM
