Drag filter options
Old Jul 9, 2004 | 02:41 PM
InLimbo87's Avatar
Default Drag filter options
I just recently have been installing my turbo onto my 95 integra ls (drag manifold, turbonetics t3/t4b, etc.). problem is, i thought i could just attach a filter directly to the turbo and was i wrong. room is limited. Now, you think I can just use a 2.5" 90 degree bend, a 2.5" silicone coupler and a kn filter with a 2.5" inlet? I am not sure exactly if that diameter is correct because I am out of town also. What did you guys do for any similar setups? someone please help, I'd like to order this stuff before I leave so I can have it up and running as soon as I can (you guys know how it is i'm sure). Thanks
Old Jul 9, 2004 | 04:46 PM
FORCED FED TEG's Avatar
New User
Default Re: Drag filter options (tegsedan)
My kit came with two 3" 90s but they did not fit right, So I used a 3" dryer vent and made a cold air box for my filter.
InLimbo87's Avatar
bump
Old Jul 9, 2004 | 04:48 PM
InLimbo87's Avatar
i looked for the dryer vent at home depot but couldnt find it, i had seen someone else suggest it. where did you find it? was the outer diameter 3 " ?
Old Jul 9, 2004 | 04:52 PM
InLimbo87's Avatar
i also think that the diameter on my compressor inlet is less than 3 ". I have the turbonetics t3/t4b which is from the si kit i believe. anyone know the diameter on it ?
Old Jul 9, 2004 | 04:53 PM
New User
I got mine a home depot they should have it just ask. It 3" inter diameter. I have a GSR kit on a LS
Old Jul 9, 2004 | 04:58 PM
InLimbo87's Avatar
Default Re: Drag filter options (FORCED FED TEG)
i just wised up and looked up the diameter and it was 2.75 inches. thats what i thought it might be. do they have a lot of sizes for the dryer hose?
Old Jul 9, 2004 | 05:07 PM
New User
Just get a 3" and clamp it down. It's made out of aluminum so it will squash down a 1/4" no problem. They only make dryer vent in 3" and up.
Old Jul 11, 2004 | 02:31 PM
InLimbo87's Avatar
anyone have luck with just a u-bend? anyone know where 2.75in. u-bends might be carried. jcwhitney doesn't have them. i couldn't imagine using dryer hose for more than temporary use.
B18EG6
Jul 16, 2007 05:49 AM
threatcon13
Mar 30, 2007 09:40 PM
Wicked Sol
Jun 7, 2003 09:17 PM
2000GSRT
Nov 15, 2002 02:06 AM
