Downpipe question...
Old Apr 22, 2007 | 05:13 AM
SlowSOHC-T's Avatar
Default Downpipe question...
I'm running a 3" downpipe with a 2.5" flange. The meaning that there is a lip from the flange that sits inside the downpipe. Should I bore out the lips to make them 3"? Or will I be fine?
Old Apr 22, 2007 | 05:30 AM
Adriano's Avatar
Default Re: Downpipe question... (SlowSOHC-T)
Assuming you are talking about the turbo outlet flange. Just match it to the turbo exhaust outlet size. Most t3/t4 are 2.5 anyways.
Adriano
Old Apr 22, 2007 | 06:41 AM
SlowSOHC-T's Avatar
Default Re: Downpipe question... (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">Assuming you are talking about the turbo outlet flange. Just match it to the turbo exhaust outlet size. Most t3/t4 are 2.5 anyways.
Adriano</TD></TR></TABLE>
Not sure what you didn't understand, I'll try and explain it better. But I have a T3 Downpipe flange that has an outlet cut out for a 2.5" piping, all I have is 3" piping and I welded it to the flange. This is leaving a .5" lip all the way around between the downpipe and the flange. Im just curious if I'll have any issues out of it, such as maybe turbulence or anything like that? And if so should I bore out the flange the extra .5" to make it 3" all the way around? Any info would be great..
Old Apr 22, 2007 | 07:45 AM
BlueSi2k's Avatar
what size is the outlet on the turbo?
Old Apr 22, 2007 | 10:37 AM
PrecisionH23a's Avatar
Run a 2.5-3" flare. As long as the OD of the flange flange matches the OD of the turbine exhaust you're fine.
Old Apr 22, 2007 | 04:17 PM
SlowSOHC-T's Avatar
Its a small T3 .42/.48 ar. Its exhaust wheel/outlet is only 2" and the flange is 2.5".. The turbo normally runs an internal wastegate in which I eliminated and bought the plate that blocks it off and now running a Tial External....
I guess I need to make a new downpipe? Its only going on a D16 on 7psi... I
Old Apr 22, 2007 | 07:06 PM
BlueSi2k's Avatar
Default Re: (SlowSOHC-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowSOHC-T &raquo;</TD></TR><TR><TD CLASS="quote">Its a small T3 .42/.48 ar. Its exhaust wheel/outlet is only 2" and the flange is 2.5".. The turbo normally runs an internal wastegate in which I eliminated and bought the plate that blocks it off and now running a Tial External....
I guess I need to make a new downpipe? Its only going on a D16 on 7psi... I </TD></TR></TABLE>
I would run it. Its bigger than the outlet so its not like your creating a bottleneck anywhere.
Old Apr 22, 2007 | 07:12 PM
SlowSOHC-T's Avatar
Default Re: (BlueSi2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">
I would run it. Its bigger than the outlet so its not like your creating a bottleneck anywhere.</TD></TR></TABLE>
Man you made my day.. That's exactly what I was thinking.. Anyone else?
Old Apr 22, 2007 | 07:20 PM
da_dude's Avatar
You should be fine. Not recommand it unless your turbine hole is 3 inch and your discharge flange is 2.5 inch. Then I would worry about it.
Honda4life777
Jun 28, 2009 08:43 PM
huepowered
Welding / Fabrication
Jun 8, 2006 04:22 AM
nathanie1
Sep 17, 2005 09:39 PM
egg
Jun 10, 2003 01:25 AM
