Downpipe to oil pan clearance issues.
Old Jul 16, 2007 | 07:50 PM
EX-T's Avatar
Default Downpipe to oil pan clearance issues.
I've got a Vitara/Eagle built D16Y8 with a Turbonetics .57/.63 60 trim t3/t04b and a 3 inch stainless downpipe. My concernces are that the flex pipe portion of the downpipe is touching the oilpan.
Since it is the oil pan will this be okay if I try to wrap the **** out of it with heat wrap, or is there a high possibility that I might shatter my oil pan(it's aluminum BTW)?
Old Jul 16, 2007 | 07:53 PM
boosted timebomb's Avatar
Default Re: Downpipe to oil pan clearance issues. (EX-T)
just wrap it, it should be fine
Old Jul 17, 2007 | 03:47 AM
ham's Avatar
ham
i had that problem and i just flattened out the top of the DP with a hammer to make a small gap. the flexpipe touching the oil pan causes and exhaust ground which will cause an odd vibration and have bad long term effects on the motor. i tried the heat wrap too and it just made it worse.
Old Jul 17, 2007 | 06:13 AM
HiProfile's Avatar
Default Re: Downpipe to oil pan clearance issues. (ham)
Why would anyone put the flexpipe that close? Mine never go on before the axles, even when using a cat. Its just wasted ground clearance, and in this case - an invitation to disaster. One good speed bump and your oil pan will say hello to your stud girdle.
Old Jul 17, 2007 | 07:35 AM
EX-T's Avatar
Default Re: Downpipe to oil pan clearance issues. (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Why would anyone put the flexpipe that close? Mine never go on before the axles, even when using a cat. Its just wasted ground clearance, and in this case - an invitation to disaster. One good speed bump and your oil pan will say hello to your stud girdle.</TD></TR></TABLE>
It was a prefab'd downpipe and my oil pan is aluminum so I'm doubtful that it will say "Hello" to my crank girdle. It'll probably just shatter.
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">i had that problem and i just flattened out the top of the DP with a hammer to make a small gap. the flexpipe touching the oil pan causes and exhaust ground which will cause an odd vibration and have bad long term effects on the motor. i tried the heat wrap too and it just made it worse.</TD></TR></TABLE>
What kind of long term effects do you speak of?
SiRCiviC94
Mar 26, 2013 06:34 PM
STN_Pat
Nov 29, 2012 04:05 AM
Legion
Feb 17, 2008 07:55 AM
Fully_Built
Feb 6, 2008 09:21 AM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
