Downpipe clearance an issue?
Old Mar 21, 2013 | 06:19 PM
SiRCiviC94's Avatar
Default Downpipe clearance an issue?
Quick ?... My 2.5 down pipe off my bseries turbo is very close, like 1/4" from the oil pan. It doesn't touch though.
I do want to heat wrap and possibly a heat shield but should I bother? I have it installed I like the good clearance
Old Mar 21, 2013 | 06:22 PM
4genaccordfreak's Avatar
Default Re: Downpipe clearance an issue?
Just wrap it if you are too cheap to modify it for proper clearance from the oil pan.
Old Mar 21, 2013 | 07:24 PM
SiRCiviC94's Avatar
Lol it's prob cheaper to make it lower. But I'm wondering if the pan reflects heat enough to be ok? Normally there's a hot cat converter right there anyway
Old Mar 21, 2013 | 07:56 PM
The catalytic converters on obd1 and early obd2 vehicles are much further back than the oil pan, at the rear end of the sub-frame. Oil pans are steel, they CAN absorb radiant heat. It is not as significant while the vehicle is moving and cool air is rushing by, but more when sitting still, idling in traffic. In "extreme" cases, overheating the oil. Never physically seen this, but the theory is there.
I usually keep atleast 1"-1.5" of clearance from the oil pan. Worst case scenario, you wrap the DP and apply reflective tape to the bottom of the oil pan.
If it were my own vehicle, I would modify the downpipe.
Old Mar 22, 2013 | 04:44 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
1/4" is too tight for my liking as well. BUT get some quality wrap and reflective tape/shielding and it will be fine.
Old Mar 22, 2013 | 06:41 AM
LightningTeg's Avatar
Community Builder
Wrapping my downpipe probably netted me a few degree decrease in normal driving temps. Also noticed the oil take a little bit longer to get up to temp.
Old Mar 25, 2013 | 08:53 AM
xile6's Avatar
ah my downpipe is pretty much touching on my y8. Been running for a yr without problems of overheating oil. But also i have stainless steel piping and it drops the heat fast.
And i would have to say no tothe wraping because if the wrap gets oil in it from an oil leak. It will burn and can catch fire.
Old Mar 25, 2013 | 01:00 PM
DO IT ON ALL FOURS
Put down the drugs kid.
Old Mar 25, 2013 | 01:11 PM
SiRCiviC94's Avatar
I'm not allowed to have oil leaks lol it's my own rule.
I noticed its actually the fat *** flex that's the clearance issue the stainless pipe is clear... The metal flex part bulges out 1/2" maybe. And prob doesn't get super hot.
I'm leaving it for now I may tape the pan tho. I can't be bothered till its tuned and ready for fine tweaks like this
Old Mar 25, 2013 | 01:41 PM
DO IT ON ALL FOURS
If it is the flex pipe then that is even less to worry about. Use a temp gun, you will see the difference.
Old Mar 25, 2013 | 11:49 PM
93h2beg's Avatar
i just weld it all together, the pipe to the pan, the pan to the block. that way i don't have to guess about heat transfer. I know what i got!
Old Mar 26, 2013 | 03:21 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
most early honda stuff has the pipe practically on the pan wasn't an issue, but i have wondered myself, have the down pipe and header ceramic coated is your best option, that will lower your under hood temp, reduce oil pan temp transfer, and heap the heat where it belongs
Old Mar 26, 2013 | 03:22 AM
edit didnt see turbo, i would just have the downpipe coated
Old Mar 26, 2013 | 06:11 AM
KeithsDAteg's Avatar
You didn't know Stainless Steel dissipates heat faster than aluminum?
ROFL
Old Mar 26, 2013 | 07:22 AM
DO IT ON ALL FOURS
ROFL
I am not sure if this is directed towards me negatively or making fun of the other user. So for right now I will take neutral ground... here take a look at this:
http://www.engineeringtoolbox.com/th...als-d_858.html
If you don't understand that, then don't talk to me again. I am not some stupid punk *** kid.
Old Mar 26, 2013 | 07:26 AM
Community Builder
Woow lol
Old Mar 26, 2013 | 08:35 AM
On a serious note,you can get that downpipe jet hot coated inside and out, for one pipe its. Not crazy expensive, that would make a serious difference in heat transfer
Old Mar 26, 2013 | 01:54 PM
SovXietday's Avatar
He's making fun.
OP you will be fine, the outside of the flex pipe is just a sheeth covering the actual flex pipe that's on the inside. It won't get hot enough to cause any issues. In fact, I like to run the downpipes I make tucked up nicely along the oil pan, since everyone's gotta be stanced now-a-days.
Old Mar 26, 2013 | 03:59 PM
KeM1si08's Avatar
as stated numerous time, just wrap it and you will be fine.
Old Mar 26, 2013 | 06:14 PM
SiRCiviC94's Avatar
Ill check the heat gun on it just for *****. Wrap it later as long as that's not any fire risk.
The modification made the exhaust move a bit and muffler need shortened to tuck properly. I hate exhaust work. It's also a bit stiff under the car where normally it's a bit loose and can move an inch or more back an fourth. Spring is here the testing begins
Old Mar 26, 2013 | 06:34 PM
wantboost's Avatar
Who is Mr Robot?
The oil pan, since it is steel, will absorb the heat from the downpipe, this means it also heats the oil in the pan.. while this may help the oil get to temp faster, during aggressive driving the downpipe will cause the oil to heat beyond its service limit, I.e start prematurely degrading
Wrap the downpipe completely and you'll avoid this, you'll also notice a drop in under hood temps as well
STN_Pat
Nov 29, 2012 04:05 AM
JdmMidWest
Feb 20, 2012 05:20 PM
Fully_Built
Feb 6, 2008 09:21 AM
Pat
Feb 17, 2004 06:23 PM
