Dowel Pins...
Old Nov 24, 2002 | 11:13 PM
Evil EG's Avatar
Default Dowel Pins...
Well I took my head off last week and I look at it sitting on the grond and noticed a little dowel pin lying on the ground next to it and couldn't figure out where it fell from. Im pretty sure it goes on the head.... So heres a piture there are the two big ones on the bottom and then this little one I have no idea where it goes. So could someone point me in the right direction.
Old Nov 24, 2002 | 11:27 PM
accordking's Avatar
Default Re: Dowel Pins... (BVM)
if you look at the cam journals where the caps go you will see a hole between 2 and 3 cylinders. their should be a rubber o ring with it stuck in the head.
Old Nov 24, 2002 | 11:31 PM
wHOAlly's Avatar
Default Re: Dowel Pins... (accordking)
yeap, the middle cam cap has an o ring and that dowel pin, its how oil is routed to the oil bars
Flamenco-T's Avatar
there you go
Old Nov 25, 2002 | 12:48 AM
ninesecrx's Avatar
Default Re: Dowel Pins... (Flamenco-T)
and by the way, your a very lucky man. If you didnt notice that sitting on the floor and put it back together without that...no vtec and you would have had no idea why. Just make sure you do still have the o-ring there as well.
Old Nov 25, 2002 | 08:37 AM
Evil EG's Avatar
Default Re: Dowel Pins... (ninesecrx)
thanks alot guys.
Old Jan 22, 2003 | 06:20 AM
whitelightning's Avatar
thank GOD for searches...i took my head off, drained all the oil out in an oil pan by holding the head over a pan, dumped the oil in a container using a funnel and found the little dowel pin stuck in the funnel, did not know where it came from...shew
Old Jan 22, 2003 | 06:45 AM
PWRVTEC's Avatar
Default Re: Dowel Pins... (whitelightning)
Hummm. I lost both of those pieces and then just put a rubber o-ring there to seal the hole and my VTEC still works....
Muckman
Sep 11, 2011 04:58 PM
nominous
Dec 12, 2008 09:53 AM
1991civicsi
Apr 12, 2008 06:49 PM
njracer
Jan 29, 2008 09:51 AM
B18C_EJ8
May 22, 2007 12:08 PM
