dohc zc vitara
Old Mar 27, 2009 | 09:51 AM
89CRXProject's Avatar
Default dohc zc vitara
alright so this is what im building
i dont plan to make 400+ hp like these other guys, but i do plan to be running 12-16ish psi xxx/hp (probably 300ish) if you need me to post my info on what i will be using for the setup that you guys need to know, for anything i need to know i will be happy to answer later
also is there a difference in diamater between the sidewalls of the stock sleeves of the 3rd gen zc compared to the other d16's?
Old Mar 27, 2009 | 10:07 AM
Autoworks's Avatar
Default Re: dohc zc vitara
Its not the bore diameter you need to worry about, it is the fact the Vitara piston in the DOHC ZC will net you a CR somewhere in the 6s probably.
Old Mar 27, 2009 | 07:21 PM
oh wow that is low cr, why would that happen? so it would probably be best to use some stock p7 pistons with some good strong rods? and just use my normal bolt on fuel/intake items and call it good?
i would like to hear more about people with vitara zc's, everyone is using these sohcs' and i have a a6 z6 and a zc and a d15b2 (LOL) lying around and i was planning on building the zc, but i might just use the z6 and build the a6 if that is the case
TurboHondaGuy
May 16, 2006 02:43 PM
miketurbohonda
Apr 10, 2004 06:39 PM
91hatchcivic
Sep 12, 2002 08:04 PM
ZCREX
Nov 21, 2001 01:33 PM
