Checking for headgasket leak on E-85 running car
Old Mar 27, 2009 | 07:17 PM
undrpresur's Avatar
New User
Default Checking for headgasket leak on E-85 running car
After a 4th gear pull today my car started to overheat and when I poped the hood I noticed my coolant reservor spewed coolant all over one side of my engine bay. So I grabbed a headgasket/combustion leak tester and checked my coolant with it. It came out negative for a comustion gasses in my coolant. So then I started my car and held the tester right in the end of my exhaust pipe, sucked some of the exhaust through it and it and the blue liquid barely changed colors. My question is, do these combustion gas testers look for somthing given off by gasoline or should it work the same for E-85 users also?
Old Mar 27, 2009 | 07:23 PM
SilverEk3dr's Avatar
Default Re: Checking for headgasket leak on E-85 running car
Time to do leak-down and compression test. Those hydrocarbon testers are kinda cheating and I wouldn't completely rely on it.
Old Mar 27, 2009 | 07:41 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
u have a busted headgasket. just change it. same happen to me when i was on stock head studs.
SVOHK
Jan 21, 2013 10:37 AM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
NoVALude
Dec 31, 2006 12:40 AM
akaEsCo01
13
Dec 8, 2004 01:27 PM
Sleek98
10
Sep 19, 2003 10:58 PM
