does boost affect spooling?
Old Sep 19, 2001 | 08:20 PM
SIK IN DA HED's Avatar
New User
Default does boost affect spooling?
i was curious if anyone here boost or boosted low (1, 2 ,3+) on their daily drivers. i commute alot so i got an electroniz boost controller for the purpose of lowering the boost pressure as well as turnin it up to race.
i was just wonderin if boostin low affects the spool "noise". has anyone experienced a low spool noise when they boost low? i like the hhiiIIIISSSSSSSSSSS noise when i hit the gas. i was wonderin f it still boosted pretty loud at full throttle on low boost, for example 3lbs.
Old Sep 19, 2001 | 08:23 PM
LsTurbo91's Avatar
Default Re: does boost affect spooling? (dlplayboy)
I hear that right before I get into boost like 5inhg.
Old Sep 20, 2001 | 05:41 AM
newsense's Avatar
New User
3 psi??? you can turn your boost down that low with a boost controller?.......which one do you have, and what spring wastegate are you using?
Old Sep 20, 2001 | 05:46 AM
Ubermensch's Avatar
Default Re: does boost affect spooling? (newsense)
I'm wondering the same thing ^
Old Sep 20, 2001 | 06:35 AM
dustin's Avatar
Default Re: does boost affect spooling? (Ubermensch)
You wasted your money then... you cannot boost lower than the spring in your wastegate.
Dustin
Old Sep 20, 2001 | 02:59 PM
New User
Default Re: does boost affect spooling? (dustin)
so why is it that i cant boost lower than my spring? i got a 7lb spring. when you install the boost controller and you connect the vacuum to the wastegate... do you have to turn the spring all the way down? or do you turn it up?
the thing is... i dont see why i cant boost lower than 7lbs. my cousin boost 3lbs on his delta wastegate for daily driving. then raises it to 5-6 when he races. i just keep it at 5, but i turn it up to 6-7 when i race. whats the problem with doin that on an electronic controller?
by the way, i got a profec B on the way.
[Modified by dlplayboy, 4:01 PM 9/20/2001]
Old Sep 20, 2001 | 03:01 PM
dustin's Avatar
Then your cousin has a lower pressure wastegate spring. It also depends on where your wastegate is reading pressure from. If is is using the manifold (recommended for no EBC) then you will always boost exactly what the spring in the wastegate is rated. If it is hooked up to the compressor or somewhere before the intercooler, you will boost less because of pressure drop across the IC and piping.
Dustin
Old Sep 20, 2001 | 03:02 PM
New User
hey newsense,
team ultraspeed... do you guys got a picture of ultraman that goes withyour sticker? just wonderin cuz i saw a guy with a white integ with a black widow kit on his car. it was primered and he has a drag kit. i think hes from virginia but hes livin in cali now?
Old Sep 20, 2001 | 03:44 PM
maxim's Avatar
Dustin
Ok, stupid question....why do you not want the wastegate over the maniford if you are using an electronic boost controller? Do you always, say hook it up to the compressor if you are using an EBC?
1990hondaHF
Jan 16, 2008 11:57 AM
c61lude
Jan 19, 2006 04:34 PM
all go teg
Aug 5, 2005 04:56 AM
turbo95eg6
Jun 12, 2005 12:15 PM
accordfreak
Dec 25, 2001 12:20 AM
