does any one think this is possible
Old Jan 21, 2009 | 02:22 AM
Navy_CRX's Avatar
Icon6 does any one think this is possible
ok I kinda had a dream of a crazy idea. is is possible to make a quad turbo k20 with individual throttle bodys. I know that it would need a custome turbo manifold.what kind of wastegate and blow off valve would I have to run. I was thinking a custom topmount innercooler with 4 in and 4 out to each of the throttle bodys. what would have to be done for exaust dual h pipes or dual y pipes. also what kind of engine management could I use. as far as turbos I was thinking 4 tiny t3s. post any ideas on this. I know its crazy but anything can be done with enough time and money.
thanks
Eddie
Old Jan 21, 2009 | 03:16 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: does any one think this is possible
your last sentance makes the most sense of all of that.
if you are looking at little t3's, just get ones that are internally gated. that will save alot on plumbing. if you plan on 4 itb's and 4 separate tracts for the air, you will need 4 bovs.
to me it just seems this is for the wow factor and nothing more.
Old Jan 21, 2009 | 04:28 AM
Dren's Avatar
I agree with the wow factor comment. And yes, anything can be done with enough time and money, but should you pursue it?
Tiny T3s would still be too big, look at IHI turbos like the VG1 and VQ1.
Old Jan 21, 2009 | 04:51 AM
SPOOLINmatt's Avatar
yes wow factor, people have tried twin turbos with no success
Old Jan 21, 2009 | 08:11 AM
MadScientistMatt's Avatar
Such a thing could physically be welded together, could make enough boost to read with a boost gauge, and wouldn't even need that much more complicated engine management than a single turbo other than having multiple wastegates. So on one level, sure, it's possible.
But making that work better than a correctly designed and tuned single turbo setup? I doubt that's possible.
Old Jan 21, 2009 | 08:14 AM
Boostage's Avatar
You guys are actually entertaining this? Honda-tech you are slipping there should have been a barrage of flames by the 2nd post.
Old Jan 21, 2009 | 09:20 AM
Schister66's Avatar
Man U FTW
It IS possible, but would be a plumbing nightmare. If you really want to boost it, stick to a single turbo and save yourself the headache. Personally, i dont really get the whole "wow" factor from something different...i'd rather have something fun and "practical"
Old Jan 21, 2009 | 09:44 AM
this is a lame idea yes. No doubt.
Old Jan 21, 2009 | 10:00 AM
Bseriescivic5's Avatar
Who is going to make him a manifold to start with, second your talking at least 1200-2k just for a custom manifold. third, good luck fitting 4 turbos (even if they are tiny) in the engine bay, Holy heat soak, just a royal pain in the ***, and the wow factor, well that doesnt even factor in when you figure all the F-bombs dropped trying to put this thing together. Who cares about the "wow" factor when you drive a honda.....hmmm yeah.
Old Jan 21, 2009 | 01:18 PM
Mr. Badwrench
every now and them even ht can have a meaningful discussion w/o flame suits he hee.
Old Jan 21, 2009 | 10:34 PM
blwn95civic's Avatar
Just do it but put up good pics during the process, i wanna see if this build even gets finished or downhill from day 1.
Old Jan 21, 2009 | 10:43 PM
ntoxicatedtigah's Avatar
ok i am just gonna give u some negative reinforcement , creative idea but totally dumb.
Old Jan 21, 2009 | 11:21 PM
Tony the Tiger's Avatar
Not possible, just because you won't really find any useable turbo that is sized correctly to feed 500cc if displacement each and make it work. Also, having one cylinder feed each turbo simply means there will be huge gaps between exhaust pulses. The turbo probably never spools correctly, and the car will make almost no power, way more lag, and basically, a piece of expensive junk after you are finished with it.
forceinducted
May 12, 2012 11:10 PM
Golden Eagle
Performance
Oct 1, 2010 10:55 AM
Fastjato33
Jul 18, 2009 11:53 AM
Boosted_eg19
Dec 30, 2008 04:55 PM
TurboJesse
Honda Motorcycles
Jan 19, 2003 08:13 AM
