Do standalone ECU's "learn"
Old Mar 28, 2003 | 09:15 AM
MiraiZ's Avatar
Default Do standalone ECU's "learn"
Just wondering if aftermarket ECU's learn? What I mean by this is, any time you make changes to you car, an OEM ecu will eventually learn the changes ( or you would pull the power for a few seconds and to reset it)
Does a standalone do the samething or is it purely manually porgrammed?
Old Mar 28, 2003 | 10:05 AM
boosted hybrid's Avatar
Default Re: Do standalone ECU's "learn" (MiraiZ)
The standalones that i have tuned with including DFI, Haltech and somewhat with FAST dont. They strickly read the maps that you create, and dont learn the characteristics of your engine like the stock honda computer.
Old Mar 28, 2003 | 10:06 AM
TurboDANDEE's Avatar
i believe that the only learning it does is the wideband option, it corrects the fuel itself if its running rich or lean. other than that, everything else u have to set up yourself. but once u dialed in everything, there shouldnt be a problem because theres no need for the ecu to learn itself, everything should run smooth.
anyone else?
Corksil
23
Jul 14, 2011 05:59 PM
erikiksaz1
Engine Management and Tuning
Jun 11, 2010 02:39 PM
SiRex91
Apr 13, 2003 05:06 PM
