do i need a different ecu
Old Jan 25, 2006 | 03:00 PM
donvito#1's Avatar
Default do i need a different ecu
what up im ready to turbo my crx what i got so far d16z6 engine, t3/t4 gareet tubo kit, fuel pump, 550cc injectors, fmu, missing link,stage 2 clutch &light weight flywheel,boost controller,boost gauge if im missing something tell me and do i have to do anything to the ecu
Old Jan 25, 2006 | 03:29 PM
BlackCRX's Avatar
550cc injectors will not run on a stock ecu
since you have the fmu and missing link i assume you would need to get a v-afc or s-afc
that or you can ditch the fmu/missing link and mod your ecu to run an ems
assuming you are obd1 your choices are crome, uberdata, hondata etc..
Old Jan 25, 2006 | 04:56 PM
donvito#1's Avatar
Default Re: (BlackCRX)
what is a v-afc or s-afc and what do they do and how would you install that
Old Jan 25, 2006 | 04:59 PM
93turbo16's Avatar
Ok first off. Read the FAQ, there are tons of posts about this.
BUt what you really wanna do is, ditch the FMU and the Missing link. Get your ecu chipped with turboedit for OBD0, or the best option is convert to OBD1 and run Uberdata or crome. That is your best bet. Then take it to a reputable tuner and let him do the rest.
: Forgot, you can't use PMs yet. If you have any specific questions you could email me at john@j-k-tuning.com
Old Jan 25, 2006 | 07:27 PM
SiAutoX's Avatar
Default Re: (93turbo16)
NOTE* DO NOT stick those 550cc injectors in your can and start it up b4 tuning.....they will flow too much fuel and burn off all oil arround pistons and wha-bamo rings are gone and probibly pistons....i did this and within the first 15 seconds my car was puffing out blue smoke let it keep running thinking it would clear out and 10 seconds later it locked up....... I say install the turbo kit with stock injectors, dont boost and take it to the closest tuner, when you get there install the injectors and let him have at it. Keep us posted on how it goes
Bump for another EF turbo
Old Jan 25, 2006 | 07:40 PM
donvito#1's Avatar
Default Re: do i need a different ecu (snoopdpg)
hey does anyone know how i set up the vaccuem lines on a 91 crx d16y7 with a t3/t4 turbo kit where does the lines go
Modified by snoopdpg at 11:31 AM 1/27/2006
blasterman87
Engine Management and Tuning
Oct 24, 2009 05:04 PM
Live*JDM
Northern California (Sales)
Jun 26, 2007 03:33 AM
commotion
Jun 20, 2006 07:42 AM
commotion
Jun 19, 2006 08:27 AM
bluebullet
Jul 5, 2003 08:26 PM
