Do I NEED a catch can?
Old Apr 19, 2011 | 08:16 PM
GoSickemRobert's Avatar
Default Do I NEED a catch can?
Setup:
stock gsr head
stock gsr block
9:1 cp pistons
eagle h beams
880cc injectors
I'll be getting tuned on 16-17psi on friday.
I dont have a catch can at the moment but I want to know if i need one for my setup. It's going to be 350+whp I believe. And if I did need a catch can, can I just gut the pcv valve and go straight to a catch and not run a line to the intake mani? I hear some people that dont use catch can unless its crazy horsepower so thats why I'm asking. Thanks
Old Apr 19, 2011 | 08:23 PM
mark11017's Avatar
Default Re: Do I NEED a catch can?
i would deff use one with that kind of psi/power goal.. at least use the 2 ports on the back of the block if you dont want to weld the valve cover bungs
Old Apr 19, 2011 | 08:30 PM
yeah I dont have bungs welded on the valve cover. Im getting the tune in 3 days so I got to find a way to get this engine breathing nicely. How would I do the two ports on the back?
Old Apr 20, 2011 | 06:50 AM
mark11017's Avatar
theres a kit out there i cant remember the name, i think moroso makes one. just type into google for a breather kit. you need to fittings on the back of the block i believe they are from an h22 they use them as a water fitting. the kit would come with them though. t1 has a nasty system but thats 500$
Old Apr 20, 2011 | 07:06 AM
yeah i saw t1's and i want it. but yeah its a little up there.. can i just make a catch can, gut the pvc valve run that like to a catch can and plug the intake port? or is that to little of a line and not enough?
Old Apr 20, 2011 | 07:48 AM
93lsv_turbo's Avatar
If it was me I would get it tuned then have it done right. As long as you have a pcv system you should be alright. The worst thing thats gona happen is you'll push out a seal. You can fix that without a retune. Welding on the valve cover isn't easy, not everyone can do it. The back of the block is nice but it pushes ALOT of oil. I made a homemade catch can with a spray paint can. I jb welded the fixings to the valve cover and have them look good. You just have to prep everything extremely well. Then when you have the time and money get then welded. It will work
Old Apr 20, 2011 | 07:54 AM
darkvader0's Avatar
You asked if you NEED a catch can, and IMO you don't NEED one.
I have had the same turbo setup on my same 98 Integra for 12 years now. Have run up to 29psi and 500+ hp. I have a stock PCV setup with the exception of a little K&N filter stuck on my valve cover.
Old Apr 20, 2011 | 07:57 AM
welfarepc's Avatar
you dont NEED one.
you can just vent everything to the ground.
but dont expect that to fly at the drag strip. you oil down the track and put me into a wall im coming for you.
Old Apr 20, 2011 | 08:57 AM
yeah thats what im was wondering.. if i NEEDED one. what im going to do is just vent a gutted pcv to a catchcan then block off the intake
Old Apr 20, 2011 | 10:32 AM
the only thing i ever heard about the stock pcv valve is that it may get pushed open under boost.... i heard someone say something about using a stock toyota pcv valve meant for their boosted cars
Old Apr 20, 2011 | 11:59 AM
LightningTeg's Avatar
Community Builder
You'll realize you need one when oil starts leaking all over the motor and you cant figure out why. I didnt have one when I first had a stock motor build. When I started upping the boost oil started shooting out my dipstick hole and pushing past the VC gasket.
Old Apr 20, 2011 | 12:44 PM
98integralsB18's Avatar
I think you'll be alright to get it tuned with out a catch can, but after the tune, I would work on getting one quick.
Old Apr 20, 2011 | 02:34 PM
Stopsign32v's Avatar
Loved
Just get one! If you can't afford a catch can you can't afford to have a turbo on your car.
Old Apr 20, 2011 | 03:35 PM
rico892002's Avatar
i made 440whp on my gsr...pretty much the same set up u have...and i dont have a catch can..i kinda think they are a lil over rated...some people think, if u dont have one your motor is gonna blow lol...but when i push my closer to the 500, im goin to put one in running off the valve cover, thats about it.. I also think imo, that it depends how much u beat on your car too.
Old Apr 20, 2011 | 03:57 PM
Loved
What is the k&n part number for the valve cover breather? I don't want a cheap *** autozone one.
Old Apr 20, 2011 | 04:10 PM
Community Builder
Lol what difference does it make?
Old Apr 20, 2011 | 06:39 PM
ashb82's Avatar
LOL!!!!!!!!!!
Old Apr 20, 2011 | 07:30 PM
Loved
I will know in my heart that I was a cheap bastard.
Not to mention the power difference and the fact that the Autozone one doesn't have a 1,000,000 mile warrantee.
Old Apr 20, 2011 | 08:21 PM
DelSolMarine's Avatar
Call Brian @ B&R Fittings- 831-262-6468 for a 2 port drain back kit. That would be a great setup. 2 lines off the back of the block into a single filter catch can...
Old Apr 20, 2011 | 10:32 PM
JDM B20 EH2's Avatar
You dont have to have them welded into the valve cover either. It looks nicer but you can always run bulkhead fittings through the valve cover. It has Teflon washers on both side to seal up nicely. They will seal nicely, hold up to the temp(648*F melting point), and they will also hold up to the chemicals(oil and gas).
Something like this on the fitting. You can get them with 2 Teflon washers not ust one, or you could just order extra Teflon washers.
http://www.summitracing.com/parts/RUS-670870/
Old Apr 20, 2011 | 11:14 PM
im doing a vented vc just to be safe.
/closed yall
Old Apr 20, 2011 | 11:15 PM
but thanks for all the info, made choosing a little easier
Old Apr 20, 2011 | 11:49 PM
B R Fittings's Avatar
Since we're talking about catch cans here are some new products that we'll be coming out with.
Polished
Anodized black
Features:
*3 -10 female bungs
*stealth mounting design
*Internal baffle to keep oil inside the catch can
*The top of the catch can spins off
Also a new b-series block plug adapter with -10 male bung. Just remove the stock black box and insert. Its pictured without the holding bracket. It will come with a holding bracket which goes around the fitting and attaches to the block.
Its the fitting on the bottom right.
Old Apr 20, 2011 | 11:52 PM
Have a block fittings for a D series? I have only seen just a couple and they are in the $60 to $70 price range. If a company could make some of these at a price about half that and still make a profit I think they would sell like hot cakes.
Old Apr 20, 2011 | 11:55 PM
Pm'd.
