do i need catch can??
Old May 19, 2009 | 06:55 AM
s200silver's Avatar
Default do i need catch can??
hey i am building a fully built b16 to make 500whp after tune. now my ? is do i need a oil catch can or will it be ok with out it? this car isnt going to be daily driven prolly only have like 10000 miles at the end of summer. thanks for the help
Old May 19, 2009 | 06:57 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: do i need catch can??
honda engines cant breathe well stock. do you need one? no. will it help immensely? yes.
fwiw, the endyn worked fine for my b16 at 500whp.
Old May 24, 2009 | 05:38 PM
hayden187's Avatar
Where can I get a good one?
Old May 24, 2009 | 05:58 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
T1 & B N Rfittings both sell good cans
Old May 25, 2009 | 03:03 PM
[Ennis_D]'s Avatar
Trust me, get one. I went with a shitty one pulling off of valvecover nipple and it blew my rear main early in the tune. Just purchased a T1R set-up
Old May 25, 2009 | 03:29 PM
Whatever's Avatar
If your not pressed about the "bling" factor, you can put together a vented valve cover/catch can setup pretty cheap. If you go with AN fittings, stainless steel hose etc... expect to spend $250+. B & R has some really nice kits that come with everything you need. I'm cheap and don't care about the bling so I put one together for under $150.
Old May 25, 2009 | 04:12 PM
civic-r11's Avatar
I am getting a catch can too, but i was looking at the b&r one, and i am not sure if i should get it catch only or catch and drain back. What do you guys think about that? which one to pick???
Old May 25, 2009 | 04:22 PM
marcj's Avatar
I made my catch can out of a big rockstar drink can, with the twist top, put a little filter on top, used some brass nipple fittings. works like a charm!
you don't need to spend $250 to vent your positive crank case pressure. These guys generally have more money than crafty skills around here.
Old May 25, 2009 | 04:34 PM
LightningTeg's Avatar
Community Builder
I plan on running some 3/4s" brass nipples jb welded off the valve cover to a custom box of some sort. Hoping to spend less then $50 on the whole thing.
hatcht9x
Jul 22, 2009 07:06 PM
wicked2night
20
Jun 3, 2006 09:13 AM
ComputerJLT
Welding / Fabrication
21
Dec 11, 2004 06:25 AM
