Do I need the 2nd o2 sensor?
Old Feb 10, 2006 | 06:36 PM
asianspeed's Avatar
Default Do I need the 2nd o2 sensor?
Do I need the 2nd o2 sensor on my '99 teg ls, the one after my cat? I plan on running a 3" straight through pipe off of my downpipe, no cat, just muffler. I'm runnin uberdata and I think I recall there being a setting that I can disable the 2nd o2 sensor, is this correct? If I don't have the 2nd o2 sensor will I be able to run in both open and closed loop?
Anyone know?
Old Feb 10, 2006 | 06:42 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Do I need the 2nd o2 sensor? (asianspeed)
you can disable it... just remember you need it to pass emissions when you convert back to obd2
Old Feb 10, 2006 | 07:28 PM
asianspeed's Avatar
Default Re: Do I need the 2nd o2 sensor? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">you can disable it... just remember you need it to pass emissions when you convert back to obd2</TD></TR></TABLE>
There's no emissions here. They just check for stock mufflers.
Old Feb 15, 2006 | 12:42 AM
flarinpnoi's Avatar
hey..if you remove your 2nd o2 sensor ill buy it off you.....i need to pass emissions...heheh
Old Feb 15, 2006 | 04:32 AM
vaporboy12's Avatar
Default Re: Do I need the 2nd o2 sensor? (flarinpnoi)
when goin obd1 you do not need th second sensor the computer doesnt pick it up
Old Feb 15, 2006 | 12:27 PM
scartail's Avatar
As I recall, the obdI ecu doesn't use a 2nd sensor at all. Which is what you converted to when you went with uberdata.
Old Feb 15, 2006 | 07:22 PM
asianspeed's Avatar
Default Re: Do I need the 2nd o2 sensor? (scartail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail &raquo;</TD></TR><TR><TD CLASS="quote">As I recall, the obdI ecu doesn't use a 2nd sensor at all. Which is what you converted to when you went with uberdata.</TD></TR></TABLE>
Sweet! Thanks, good answer!
Old Feb 16, 2006 | 10:25 AM
IntegraMastaz's Avatar
same question here, I converted to Obd1 so what can I just Cut the thing?!
Old Feb 16, 2006 | 01:45 PM
asianspeed's Avatar
Default Re: (IntegraMastaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraMastaz &raquo;</TD></TR><TR><TD CLASS="quote">same question here, I converted to Obd1 so what can I just Cut the thing?!</TD></TR></TABLE>
No, there is a conector that you can use to unplug it. Where the wires go through the body of the car there should be a rubber plug, pull that out and you'll see the plug I'm talking about.
Old Feb 17, 2006 | 03:34 AM
so true, thx a lot lol! i was about to cut it ehehe
ncpk1234
Mar 18, 2009 06:40 PM
CivicExMaster
25
Oct 15, 2008 07:16 PM
projectPSI
Jul 21, 2004 09:37 AM
jentegraGS-R
Apr 2, 2004 02:40 AM
smacked94gsr
Sep 19, 2002 06:35 AM
