Do any of you prefer Ceramic coating?
Old Dec 18, 2003 | 11:57 PM
2000Accord5sp's Avatar
Default Do any of you prefer Ceramic coating?
I don't see too many people with it done at all. What are your guys opinions on it? I've only heard good things, any cons to doing it? (besides looks)
Old Dec 18, 2003 | 11:59 PM
Unsung's Avatar
Default Re: Do any of you prefer Ceramic coating? (2000Accord5sp)
A lot can be done with ceramic coating... combustion chamber, piston domes, exhaust manifolds, etc. I assume you're talking about exhaust manifold?
Old Dec 19, 2003 | 01:41 AM
lazerus's Avatar
Default Re: Do any of you prefer Ceramic coating? (Unsung EM1)
ceramic coat is the shiznit!
i'd do my whole exhaust from turbo/ header back if i could afford it!
Old Dec 19, 2003 | 05:15 AM
yellowturbo's Avatar
when you ceramic coat... is it the interior of the manifold or the exterior ... it seem stupid but im confused about it ?
Old Dec 19, 2003 | 06:10 AM
The Shodan's Avatar
It actually is a bit of both. It's a high temp compound coating that is sprayed onto the piece that you want to protect w/ dissipating head, and rust prevention. If you decide to coat your manifold, make sure you do it BEFORE you even mount the manifold and allow any heat to change the manifold.
you can also sand a compressor cover down to the metal, and ceramic coat it, giving it a nice shine. No rubbing, no buffing ;-)
Coating a manifold that has already been heat rusted is hard to coat..
Great stuff. I've got it all over my exhaust, manifolds and housings
Old Dec 19, 2003 | 07:25 AM
JSMC's Avatar
Default Re: (The Shodan)
what about engine bay temperature with a coated header?? does the ceramic coating keep the heat inside the header?? if so how hot is the header?? can you touch it when engine is on??
Old Dec 19, 2003 | 09:19 AM
LoSt is BlaCk's Avatar
Default Re: (JSMC)
well, my mani is still hot, and i would never touch it! but i have noticed a lot less heat in the engine bay! i use to open the hood and feel the heat on my face like i was looking into the oven, now it is much more tolerable! i give the coatings a ! i have not tried pistons or anything like that yet however i have been thinking about it for misslady's setup!
Old Dec 19, 2003 | 09:31 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Shodan &raquo;</TD></TR><TR><TD CLASS="quote">It actually is a bit of both. It's a high temp compound coating that is sprayed onto the piece that you want to protect w/ dissipating head, and rust prevention. If you decide to coat your manifold, make sure you do it BEFORE you even mount the manifold and allow any heat to change the manifold.
Great stuff. I've got it all over my exhaust, manifolds and housings</TD></TR></TABLE>
Is it possible to coat manifold that were already used?
Old Dec 19, 2003 | 09:43 AM
gelok's Avatar
Default Re: (Mpir3)
here check this out
http://jet-hot.com/pages/headercoatings.html
Old Dec 22, 2003 | 04:08 AM
QCKGSR's Avatar
Default Re: (redintegra_18)
i have my intake pipes, header,ic pipes,dp,wg pipe. the rest of the motor is swain coated, like piston crown, skirt, the combustion chamber, the intake port and exhaust ports, all valves are all done it helps out alot but real costly..
Stopsign32v
Mar 12, 2011 12:35 PM
Agtronic
Welding / Fabrication
69
Aug 22, 2009 12:10 PM
So Cal So Boosted
Jul 25, 2007 07:04 PM
PearlH22
Jun 24, 2006 06:05 PM
Civic TSI
Jun 22, 2001 10:24 AM
