DJ 2501's 95 LST Project
Old Jun 15, 2013 | 05:10 AM
DJ 2501's Avatar
Default DJ 2501's 95 LST Project
I picked up the LS Swapped 95 ex coupe for $1500 the other day. It has a fresh coat of paint (not perfect but hey) and it runs great minus some small issues.
So my plans are two stage. The first stage is to get some headstuds, and a chipped ecu and slap this turbo on the stock block running no more than 8psi. The second step will be sourcing another b18 block to build for more power.
Right now I still need some things to complete this kit and get step one going.
Arps
Chipped ECU
DSM Blue tops
Boost gauge
Wideband
Downpipe
Smaller wastegate springs
Exhaust
Oil feed and return
Manifold to turbo gaskets
Small list but it adds up quick. More to come in the coming weeks
Pics!!
Old Jun 15, 2013 | 05:11 AM
DJ 2501's Avatar
Default Re: DJ 2501's 95 LST Project
Drove two hours today and got some goodies
Old Jun 15, 2013 | 07:28 AM
TheShodan's Avatar
Moderator
Precision turbo, Genuine Type S BOV, nice.. Manifold and wastegate, I hope the gas was worth those items. But I'm sure you knew that already and have made plans for later when it goes as these are more than likely "just for now" right?
Old Jun 15, 2013 | 07:49 AM
DJ 2501's Avatar
It was mainly for the turbo, intercooler, bov, and piping.
Got the front apart to prep for the front mount and piping.
Old Jun 15, 2013 | 02:09 PM
DJ 2501's Avatar
Got the intercooler mounted, mani on and the turbo mocked up. I'm missing one piece of charge piping still. Then I need feed and return hooked up and a downpipe.
Old Jun 15, 2013 | 03:13 PM
DJ 2501's Avatar
Got the bumper cut and test fit.
Old Jun 16, 2013 | 12:12 PM
yungkhmer's Avatar
what precision turbo is that?
should have got a different manifold.
Old Jun 16, 2013 | 12:20 PM
DJ 2501's Avatar
I'm honestly not sure about the turbo, the imprint is pretty well worn. Looks like a t3 mount. The exhaust says .63 ar and the intake side says .60. Yeah the manifold came with the kit but I don't expect it to last long. Going to replace it with a cast go-autoworks manifold if/when this cracks.
Old Jun 16, 2013 | 12:33 PM
yungkhmer's Avatar
this is gonna sound stupid but it looks almost identical to my precision turbo. lol i have a pte 3431e with the same sized hot and cold size so i guess im just going to assume we have the same ****. its a nice turbo, i started seeing positive pressure by 3k. 5psi to be exact. GL on your build.
Old Jun 16, 2013 | 01:53 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Nice find
But what does 8lbs equal to again?
Old Jun 16, 2013 | 04:57 PM
DJ 2501's Avatar
Upon looking up that turbo it does appear to be the same one only mine is the 5 bolt pattern for the downpipe. I plan on running only 5psi for now on the stock engine.
Originally Posted by justYncredible
Nice find
8lbs what?
Old Jun 16, 2013 | 07:36 PM
You mentioned that you're going to run it at 8lbs but that doesn't mean anything. 8lbs for me would put me at or around 330whp (just a guess), because 10lbs for me allowed me to make 345whp
Old Jun 17, 2013 | 01:31 AM
yungkhmer's Avatar
8lbs what?
i also have the 5 bolt for the exhaust housing also. but for a cleaner setup i hit up greg for this sexy piece.
http://www.go-autoworks-store.com/vbat3doadas.html
its a good turbo in my opinion. im very happy i picked it up.
Old Jun 17, 2013 | 06:22 AM
DJ 2501's Avatar
I actually just ordered a 5psi wastegate spring. It's going on a stock engine with arps so I'm keeping the boost low for now.
Ah very nice. Yeah I'll be hitting up Greg for better parts once the car is back on the road with the pieces I do have. Until then I'm going to grab a cheapo downpipe
Old Jun 17, 2013 | 06:24 AM
DJ 2501's Avatar
The guy I bought the kit from was running the 10psi spring on a stock ls integra and blew his ring lands. I don't know about his tune, but I'm sure that was putting to much power for the stock internals. Going to cut that in half and work from there.
Old Jun 17, 2013 | 07:00 AM
kyden's Avatar
I doubt 10 lbs on any "50/57/60" trim would produce over 300whp on an LS, so yes his tune was probably bad.
Old Jun 17, 2013 | 09:44 AM
dcmatt's Avatar
Yea gotta agree here. You should pick a safe horsepower goal not just go 2lbs less then where your buddy blew up. And your not even sure if he had a good tune or what turbo you have. Find a good tuner and see what he thinks. Then use whatever boost it takes to get to that goal. Generally 300 on a healthy stock ls with arps, quality parts and a good tune is fine.
Old Jun 17, 2013 | 06:03 PM
DJ 2501's Avatar
Small update. Spent some time today and got the piping finished up and the bumper mounted. Ran some vacuum lines. Still waiting on the wastegate spring.
Old Jun 19, 2013 | 02:12 PM
DJ 2501's Avatar
Got the oil feed installed today. Still waiting on the rest of my parts
Old Jun 20, 2013 | 05:27 AM
kyden's Avatar
I would not waste my time with that manifold. i'd rather run it n/a.
Old Jun 20, 2013 | 10:09 AM
DJ 2501's Avatar
Lunch break = oil drain complete
Old Jun 20, 2013 | 10:37 AM
ls joker's Avatar
Loved
snail needs clocked at little
Old Jun 21, 2013 | 12:24 PM
DJ 2501's Avatar
Got my ebay downpipe today and to my surprise it actually fit.
Old Jun 25, 2013 | 05:18 PM
KevMiha's Avatar
To me, even though the letters are pretty worn, looks like it says precision.
Old Jun 26, 2013 | 10:45 AM
DJ 2501's Avatar
Got some goodies from Xenocron today!
Turbosmart 38mm ultragate
Neptune RTP
Wideband
