Divided turbine, Open manifold....................
what are your thoughts on this. You have a divided turbine housing and an open designed manifold. Power loss over using an open turbine? Modify the divided turbine housing at all? If so would you knife it or just round the center divider?
I know the easy way out would be to order an open housing, lets say that option is not available.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">if you design the split merge collector and utilize the twin scroll design you can get as much as 500rpm better spool...</TD></TR></TABLE>
nice to know this. On my new setup I'll make 2 manifolds that are the same but with differnt collectors.. I'll compair the 2 and show what i find...
there isnt much info out there...but you just have to think your pairing the cylinders for better pulse seperation...and using it to hit the turbine wheel at its maximine efficent pt....so itll spool better...hence why a lot of t4's are divided housings...i plan on going from a ramhorn to a divided topmount setup very very soon
anyone here using a gt30r w/garrett 3in turbine outlet with any a/c fullrace style manifold and down
eg:R
Dec 5, 2005 06:44 PM
TurboJesse
Jul 6, 2003 06:24 AM
