Distributor alignment question.
Old Mar 8, 2004 | 07:21 PM
BoostedD15B7's Avatar
Default Distributor alignment question.
What will happen if the distributor tooth is 180 degrees the other way? Will the car run? What will happen?
Old Mar 8, 2004 | 07:24 PM
turbo96wr's Avatar
Default Re: Distributor alignment question. (BoostedD15B7)
even with the bolt's in place the dist..... will wobble in place and cause damage, it is also hard to put it in the wrong way.
Old Mar 8, 2004 | 08:00 PM
Bailhatch's Avatar
Default Re: Distributor alignment question. (turbo96wr)
ya you can't really install it the wrong way because of the offset tab. You can however, install that alignment tab 180* off if you take the distributer apart. It won't run and might back fire when you crank it, not that I have made that mistake before
Old Mar 9, 2004 | 03:17 AM
thanks guys
thegreatdj8
Nov 6, 2017 05:44 AM
WhiteOnRice
20
Jan 5, 2009 07:50 AM
89D15CRXDX
Apr 1, 2007 06:54 PM
stRodda
Aug 9, 2004 12:43 PM
davekaro
Apr 7, 2004 06:20 AM
