Dirty engine make over.. Take a peek
Old May 21, 2007 | 10:09 PM
TheThiefTheKnife'NTheGun's Avatar
Default Dirty engine make over.. Take a peek
Well I picked up a stock b16 for $400 (and it was dirty), so I could drive my car while I finished my build. I decided to see if I couldnt throw down a budget turbo set up to keep me boosted while I wait. I had a bunch of stuff laying around so I threw it all together.
I picked up a greddy downpipe mani and turbo for $150 the downpipe was such trash I built a 2.5 inch one I think I will have the motor in the car next weekend!!
Enjoy
Old May 21, 2007 | 10:42 PM
Cookie's Avatar
Default Re: Dirty engine make over.. Take a peek (TheThiefTheKnife'NTheGun)
It looks like it's coming along. What car are you putting it in? What moderate hp numbers are you hoping to pull?
Old May 22, 2007 | 02:58 AM
BDogggUT34's Avatar
Nice! What was your method of cleaning up that block?
Old May 22, 2007 | 04:05 AM
delslo93's Avatar
Default Re: Dirty engine make over.. Take a peek (BDogggUT34)
That does look nice. I just got done doing the same thing with my b16 (except I got mine for free ). I painted my block with high temp paint after I cleaned it up as good as I could. Did you paint yours?? Good luck with the project.
Old May 22, 2007 | 04:08 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: Dirty engine make over.. Take a peek (delslo93)
what was the method you used to clean the block
Old May 22, 2007 | 04:42 AM
93supercoupe's Avatar
Default Re: Dirty engine make over.. Take a peek (gunslinger)
i like how a Type R valve cover and some cleaning can make a B16 go from gay to sweet.
Old May 22, 2007 | 06:31 AM
Default Re: Dirty engine make over.. Take a peek (93supercoupe)
Well I didn't paint the block I started with some simple green and sprayed it down let it soak. I then waited about then minutes and hit it with a wire brush and then hit the motor with a hose, after that it was all tooth brush and some elbow grease.
Old May 22, 2007 | 06:52 AM
Crasian's Avatar
that b16 has a auto tranny flywheel! gross>
anywho, good job with the cleanup on that b16. looks sweetup!
Old May 22, 2007 | 07:49 AM
gunslinger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">i like how a Type R valve cover and some cleaning can make a B16 go from gay to sweet. </TD></TR></TABLE> Its a budjet build and where commenting on the cleaning job . Shure b16 may suck now but show some respect to the engine that started it all
Modified by gunslinger at 2:47 PM 5/22/2007
Old May 22, 2007 | 09:19 AM
CRX T-Si's Avatar
I use this engine cleaner that only Pep-boys sells. Forgot the name but it's in a black can with the words STEAM on the side of it. Very good stuff.
Very nice man, and is that paint on the Manifold or High temp coating?
But man, those B16 Auto cams gotta go. It's like non existent for Vtec.
Old May 22, 2007 | 09:49 AM
RC000E's Avatar
Default Re: Dirty engine make over.. Take a peek (CRX T-Si)
I'm still impressed with landing a running b16 for 400 bucks. Wish I could catch those deals. I can hardly ever find good heads for 400.
Old May 22, 2007 | 10:55 AM
Default Re: Dirty engine make over.. Take a peek (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">I use this engine cleaner that only Pep-boys sells. Forgot the name but it's in a black can with the words STEAM on the side of it. Very good stuff.
But man, those B16 Auto cams gotta go. It's like non existent for Vtec.</TD></TR></TABLE>
I have some CTR cams I could throw in there, but then I guess I would need some valve springs! trying to keep it cheap
Old May 22, 2007 | 12:07 PM
French's Avatar
Looks awesome!
Old May 22, 2007 | 12:20 PM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheThiefTheKnife’NTheGun &raquo;</TD></TR><TR><TD CLASS="quote">
I have some CTR cams I could throw in there, but then I guess I would need some valve springs! trying to keep it cheap</TD></TR></TABLE>
I'll trade you my Gs-R's Still got the Gs-R springs too.
but I guess your right man. Keep it under budget.
Old May 22, 2007 | 12:34 PM
josh0407's Avatar
How Did You Get The Inside Of The Webbing Clean?
Old May 22, 2007 | 12:54 PM
Muckman's Avatar
Moderator in Chief
What kind of wire brush? Dirt and grease is easy to remove, its the oxidation that Im impressed with.
Old May 22, 2007 | 02:06 PM
gunslinger's Avatar
Default Re: Dirty engine make over.. Take a peek (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">What kind of wire brush? Dirt and grease is easy to remove, its the oxidation that Im impressed with. </TD></TR></TABLE>
Exactly!!!
Old May 22, 2007 | 02:26 PM
Dueceification's Avatar
When i did that to my engine i just used a wire brush i picked up at good old Home Depot. alot of elbo grease Then i realized i had a compressor so i picked up a air tool and put a brush on that.
That engine went from POS to bling bling
Old May 22, 2007 | 02:45 PM
Civicman86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">I'm still impressed with landing a running b16 for 400 bucks. Wish I could catch those deals. I can hardly ever find good heads for 400.</TD></TR></TABLE>
+1 I never come across stuff like that.
Motor looks real clean though! I need to clean my d16 block
Old May 22, 2007 | 03:17 PM
JoePSI's Avatar
Default Re: Dirty engine make over.. Take a peek (Civicman86)
Looks good, still rockin your spearco intercooler.
Old May 22, 2007 | 05:56 PM
Muckman's Avatar
Moderator in Chief
Default Re: Dirty engine make over.. Take a peek (Dueceification)
Yes but what kind of brush? Cuz steel would scratch the **** out of it. I bet he used brass.
Old May 22, 2007 | 06:43 PM
forum04pl's Avatar
looks really nice, im glad your putting the extra effort in. i cant stand when people do a swap and put some filthy motor into their bay
Old May 22, 2007 | 07:55 PM
.RTErnie's Avatar
Default Re: (forum04pl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forum04pl &raquo;</TD></TR><TR><TD CLASS="quote">looks really nice, im glad your putting the extra effort in. i cant stand when people do a swap and put some filthy motor into their bay</TD></TR></TABLE>
QFT
Old May 22, 2007 | 08:01 PM
Default Re: (.R T E r n i e)
I used a brass brush this way it didnt scuff the block up to bad. most of the webbing though I used the tooth brush.
Old May 22, 2007 | 10:46 PM
Danger's Avatar
Default Re: (TheThiefTheKnife'NTheGun)
nice job , cleaned up real nice
