Dirty Block
I am not sure how, but when the machine shop did all my work, they hot tanked the block (so they say) and it is still pretty filthy. I have the short block still apart and wanted to sand blast it, I am woried the blast may make it in to the cylinder walls or the crank, etc. Does anyone have any ideas how I can blast it to clean it to make it loook new?
I do not want to paint over the dirt or anything and really did not want to paint it at all, but I do not want a disgusting looking block either.
I am open to suggestions and hope someone can help me out here.
FYI, the block is still unassembled, it has been thoroughly cleaned inside and the honing is done already as well.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">just tape everything REAL well, and use bead blast instead of sand if your worried.
Landon</TD></TR></TABLE>
try that first .
try that first .
Clean the block with some cleaner/degreaser, tape as much as you can off where you don't want paint with masking tape and paint it. I use Dupli-Color High Heat Ceramic (Aluminum DH1606). I used it on my last block which had quite a bit of work done on and I will be using it on my new block.
Before ...
Before ...
Before ...
After ...
Before ...
Before ...
Before ...
After ...
After ...
After ...
Before ...
Before ...
Before ...
After ...
Before ...
Before ...
Before ...
After ...
After ...
After ...
your only blasting away at the surface , not changin the shape of it or anything . jus tape everything off like the other guy said . you should have nothing to worry about
NATEDEEZY
19
Mar 26, 2008 04:28 PM
