Differences between the T04B and T04E
Old May 14, 2002 | 12:38 AM
FredoSP's Avatar
Default Differences between the T04B and T04E
T04B - Comes with the Drag Gen 3 Kit, used for "smaller" boost applications?, quicker spool time relative to the "E"?
T04E - Also Comes with the Drag Gen 3 Kit, Better Boost potential top end as opposed to the "B", Same as above ...
Can Anyone add anything else?
ArTurbo
The T04E has 6 main blades with 12 sub-blades... these blades are rather large, so they move alot of air. The T04B has 7 main blades and 14 sub-blades.. these blades are a little smaller than the T04E's so they spool quicker but dont generally move as much air.
[Modified by FredoSP, 4:40 AM 5/14/2002]
[Modified by FredoSP, 4:41 AM 5/14/2002]
Old May 14, 2002 | 12:42 AM
FredoSP's Avatar
Default Re: Differences between the T04B and T04E (FredoSP)
How did I put D's in the title, Im a fool
Old May 14, 2002 | 05:21 AM
DragII's Avatar
The B is used in smaller displacement engine drag kits....such as the B16, and D16, and for some BIZARRE reason...the H22.
all the 1.8ltr kits come w/ an E
Old May 14, 2002 | 07:28 AM
PrecisionH23a's Avatar
Both E and B series turbo's are related. The "E" and "B" signify different families of compressor wheels. Each family was optimized for certain applications. One family is not better than the other. In some circumstances, the "E" may perform better than the "B." In other situations, vice versa. Its best to choose the wheel that will better cater towards your needs.
Old May 14, 2002 | 08:33 AM
HXMan's Avatar
Default Re: Differences between the T04B and T04E (Matthew)
This does help, but who knows what trim to4b comes in the drag kit?
Compressor maps:
4b:
http://www.turbofast.com.au/FlowTO4B.html
4e:
http://www.turbofast.com.au/FlowTO4E.html
plus the old post
https://honda-tech.com/zerothread?id=142398
might help you out.
Im not sure your question can be answered without knowing which trims you are talking about.
Again, i might be wrong!
-matthew
Old May 14, 2002 | 01:46 PM
DragII's Avatar
Default Re: Differences between the T04B and T04E (HXMan)
I do.
Old May 14, 2002 | 01:51 PM
xero-cool's Avatar
Default Re: Differences between the T04B and T04E (SuperDragII!!!)
I do.
heh
Old May 14, 2002 | 01:59 PM
jinxproof99's Avatar
New User
nice avatar HXMan...................too bad i couln't keep mine.
oooohhhhhhhhh, i have a new one now.
[Modified by jinxproof99, 6:08 PM 5/14/2002]
Old May 14, 2002 | 02:28 PM
Mr. Vapor's Avatar
Default Re: Differences between the T04B and T04E (jinxproof99)
my "E" came with a 54 trim, .63 ar..........
Old May 14, 2002 | 02:36 PM
New User
Default Re: Differences between the T04B and T04E (NYb16)
mine came 36x24x36......eerrrr....uummmm.......uuhhh.....nev er mind.
Old May 14, 2002 | 03:49 PM
apexii's Avatar
Default Re: Differences between the T04B and T04E (GudeH23a)
The actual "e" housing is physically larger on the intake side.
imonkie
Dec 11, 2002 04:53 AM
imonkie
Dec 9, 2002 10:45 PM
jinsokuSI
May 16, 2002 01:02 PM
Sohc Driver
Feb 22, 2002 02:38 PM
