differences between AC and non AC manifolds? is there one?
Old Oct 1, 2006 | 09:15 AM
b18sihatch's Avatar
Default differences between AC and non AC manifolds? is there one?
i am thinking of getting a A/C manifold but im not running as is there a major difference in the manifolds? and if i dont run ac this effects nothing right?
Old Oct 1, 2006 | 09:27 AM
speedworks's Avatar
Default Re: differences between AC and non AC manifolds? is there one? (b18sihatch)
air conditioning vs. no air conditioning
Old Oct 1, 2006 | 09:28 AM
b18sihatch's Avatar
Default Re: differences between AC and non AC manifolds? is there one? (speedworks)
well im not running ac but was wondering if i can run a ac manifold on a non ac motor. what is the difference between non vs ac is there a noticeable difference in the way the manifold is made?
Old Oct 1, 2006 | 10:07 AM
jDMJeRk's Avatar
clearances!
Old Oct 1, 2006 | 10:11 AM
BoostedEG6's Avatar
You would want a non-AC manifold since you don’t have AC.... but if you have an AC compressor mounted on your block then you would need a AC manifold.....
Old Oct 1, 2006 | 06:14 PM
boostd92's Avatar
The answer is:
IT DOESN'T MATTER.
If you don't have A/C, you can use either manifold, obviously. The A/C manifolds only change where the turbo/ewg's are located so it will clear the A/C compressor/condenser.
Skip01
Jul 26, 2011 11:28 AM
Sic_DA_Nine
Sep 27, 2006 01:23 PM
delsolnewkid
Apr 1, 2006 06:12 AM
nikolai.
Aug 19, 2005 09:46 AM
